MWI stuck on - No messagse
jmilstead
I have a phone that has the MWI on, it indicates that there is new voicemails and the envelope is blinking on the line.  However, if you login to the voicemail for that line, there are no messages.  Actions I have tried include:
- Erase reset phone
- Delete recreated the Unity account
- Assigned new # and created new mailbox for line / receieved message / then put the original line back
Any thoughts on what steps to take from here or what to look at?
8 Replies 8
ndehmer
Level 4
Level 4
Run a User Data Dump for the Unity server and select Alias, Primary MWI, and Alternate MWI.  There could be another mailbox with this extension set as an alternate MWI extension
Thanks ndehmer.  I will load the tool and let you know what I find.  Regards!
ndehmer, thanks for the assistance.  And the tool is quite helpful, but I was able to resolve this issue this morning with the following command:  utils cuc cluster renegotiate.  I ran it on the pub.  Rebooted the sub and then ran it on the sub.  The phantom messaged dropped out as the sub completed it's negotiation (it appeared).
Thanks!
This looks to have been a DB replication issue then.  Out of curiosity, why did you choose the renegotiate command?  You would generally use that if you've replaced the Publisher. Essentially, it overwrites the DB with that from the Subscriber and then sets up replication again.  Just curious to know if you have done anything with your Publisher or if this was simply a replication issue (either way - the command still resets replication in the cluster).
Hailey
The issue actually developed after completing 4-corner testing.  It's a new install, so I was ensuring everything would properly withstand a power outage, and then properly come back online to a normal state.  Initially, it had an issue with proper synchronization with the pub/sub.  Hence, your thoughts, and we did that same process to resynchronize between the two.  However, after everything came back to a proper normal state, I had the issue with the one mail box and I guess a “phantom” entry somewhere in the database.  After exhausting all the other avenues, I had a feeling it was something with the database and thought I’d at least try this to see if it might clean up the database info.  Hope that helps better understand how transitioned.
Regards & thanks for the interest.
What switch would you recommend if not the renegotiate?
I am experiencing a very similar issue with out set up.
We have been running fine for about 3 years but a few users over the week have reported MWI that wont turn off even though i have confirmed they have no messages. Some of them did not even have a unitt account for messages but came in to a voicemail light that wont turn off.
I have added them to unity and left them a message gone in and deleted and the light remains on.
i can manually turn the indicator off with the extension.
i have also reset via cuc telephony integrations.
I think this switch might be the next option
I am having the same issue. How do I run this User Data Dump?
The Cisco Unity Tools site run by Cisco / Jeff Lindborg you can find an extensive help file for this and other tools.  The specifc location for the User Data Dump tool is http://www.ciscounitytools.com/Applications/CxN/UserDataDump/UserDataDump.html  You will need to install the IBM Informix drivers as well.  There is a great walk through showing you how to do all of this on this site.
Nathan
