Need Help on UCCX Script
vaibhav-g
How we can check supervior logged in status, Like i want to check the condition for supervisor logged in particular CSQ.
Do anyone can tell the method/Script How we can prepare or any one can share sample script for supervisor logged in status Check
Vaibhav Gupta
Aaron Harrison
Any supervisor is also an agent, but the system doesn't differentiate between agents that are supervisors, and normal agents. They're just agents if they are in a CSQ.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Thanks for your response
Could you suggest the function and condition if possible can you share any script .
Vaibhav Gupta
