Outgoing Call is getting Disconnected after one ring in CME for one number
Version:Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.4(3)M3,
call Flow: IP Phone (SCCP)---Diling out using---T1--> PSTN
 after one ring call getting Disconnected
the issue is resolved, there is no issue from the router end,
call flow IP Phone(SCCP)--->CME--->T1--->Avaya PBX---> call FWD---another DID Number
Call is getting Failed to due to Delay in response after cutting down the Avaya PBX and dialing Direct DID is working Fine now,
Initially i was not aware of the complete call flow.
Jaime Valencia
What does the debugs say about the call?
java
if this helps, please rate
Hi  Java,
calling party number :8976
called party number:17817925555
adding the file debug ccapi inout, not able to run the command debug isdn q931 its not taking
