Paging System on BE6000
shanid1987
I have BE6000 installed with CUCM 10.5. I need to activate the paging on this system for all registered pones with this CUCM. Is it possible to do that without a third party software??. Please help me on this.
Nadav
Level 7
Level 7
Contrary to CME which has paging built-in, CUCM must integrate with an Informacast VM to offer paging services.The free version allows groups of up to 50 phones at a time. Keep in mind their paging works via multicast so your infrastructure should accommodate this.
thank you for your immediate reply. Is there anything need to be done for multicast in the default switches??. I have installed and configured InformaCast but its getting busy tone when i dialing to CTI route number..
Did you try using DNA to make sure there aren't any calling privilege issues?
