09-07-2023 10:38 AM
Does anyone know whether 4451 can be configured with the values of choice to use as payload numbers (types) in the SDP for initiated V.150.1 connections?
09-07-2023 12:53 PM
I imagine this would be in the config guide, but here is another community thread that lists possible values.
https://community.cisco.com/t5/collaboration-knowledge-base/cisco-rtp-payload-types/ta-p/3118109
09-07-2023 01:21 PM
Unfortunately the referenced table does not show values of 118 and 120 which are the only ones that 4000 Series uses for V.150.1 per Cisco V.150.1 Minimum Essential Requirements Configuration Guide - Cisco
09-07-2023 02:08 PM
Could you map the payload type on the dial-peer with the "rtp payload-type" command to the number you need?
09-08-2023 05:39 AM
I am only guessing here because I never see modem relay in production networks, but you probably can't specify it because it negotiates the mode relay/modem pass through.
