06-11-2018 10:37 PM - edited 03-19-2019 01:24 PM
Looking for some assistance; knowing that this topic has been covered a number of times.
New deployment of Cisco 7821 - phone receives IP address and TFTP address, but does not register.
voice call send-alert
voice call convert-discpi-to-prog
voice rtp send-recv
voice service voip
ip address trusted list
ipv4 10.220.0.36 255.255.255.255
ipv4 0.0.0.0 0.0.0.0
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol pass-through g711alaw
modem passthrough nse codec g711alaw
h323
sip
registrar server expires max 600 min 60
voice class codec 10
codec preference 4 g711alaw
codec preference 8 ilbc
codec preference 10 g729r8
voice class h323 10
h225 timeout tcp establish 3
call preserve
voice register global
mode cme
source-address 10.210.5.86 port 5060
timeouts interdigit 2
max-dn 100
max-pool 100
authenticate register
authenticate realm all
timezone 45
tftp-path flash:
create profile sync 547028220656109A
ntp-server 10.210.5.86 mode unicast
voice register dn 1
number 1004
voice register template 1
exclude directory em myphoneapp
button-layout 1 line
softkeys idle Redial Newcall
softkeys ringIn Answer
softkeys connected Endcall
no conference enable
no dnd-control
voice register pool 1
busy-trigger-per-button 1
id mac F0B2.E577.B275
type 7821
number 1 dn 1
template 1
username cisco password cisco
codec g711alaw
no vad
#sh run | sec tftp
tftp-path flash:
ip tftp source-interface GigabitEthernet0/0/2
tftp-server flash:/ccmterm/sboot78xx.11-7-1-17.sbn alias sboot78xx.11-7-1-17.sbn
tftp-server flash:/ccmterm/rootfs78xx.11-7-1-17.sbn alias rootfs78xx.11-7-1-17.sbn
tftp-server flash:/ccmterm/sip78xx.11-7-1-17.loads alias sip78xx.11-7-1-17.loads
tftp-server flash:/ccmterm/kern78xx.11-7-1-17.sbn alias kern78xx.11-7-1-17.sbn
#sh voice register tftp-bind
tftp-server url flash:/its/SEPC47295A87C5F.cnf.xml alias SEPC47295A87C5F.cnf.xml
tftp-server url flash:/its/syncinfo.xml alias syncinfo.xml
tftp-server url flash:/its/SIPDefault.cnf alias SIPDefault.cnf
tftp-server url flash:/its/softkeyDefault_kpml.xml alias softkeyDefault_kpml.xml
tftp-server url flash:/its/softkeyDefault.xml alias softkeyDefault.xml
tftp-server url flash:/its/softkey1_kpml.xml alias softkey1_kpml.xml
tftp-server url flash:/its/softkey1.xml alias softkey1.xml
tftp-server url flash:/its/featurePolicyDefault.xml alias featurePolicyDefault.xml
tftp-server url flash:/its/featurePolicy1.xml alias featurePolicy1.xml
tftp-server url flash:/its/SEPF0B2E577B275.cnf.xml alias SEPF0B2E577B275.cnf.xml
2969846: Jun 12 15:04:27.687 ADEL: TFTP: Looking for SEPF0B2E577B275.cnf.xml
2969847: Jun 12 15:04:27.709 ADEL: TFTP: Opened flash:/its/SEPF0B2E577B275.cnf.xml, fd 6, size 3882 for process 434
2969848: Jun 12 15:04:28.688 ADEL: TFTP: Looking for SEPF0B2E577B275.cnf.xml
2969849: Jun 12 15:04:28.715 ADEL: TFTP: Opened flash:/its/SEPF0B2E577B275.cnf.xml, fd 7, size 3882 for process 555
2969850: Jun 12 15:04:30.691 ADEL: TFTP: Looking for SEPF0B2E577B275.cnf.xml
2969851: Jun 12 15:04:30.715 ADEL: TFTP: Opened flash:/its/SEPF0B2E577B275.cnf.xml, fd 8, size 3882 for process 602
2969854: Jun 12 15:04:57.710 ADEL: TFTP: Finished flash:/its/SEPF0B2E577B275.cnf.xml, time 00:00:30 for process 434
2969855: Jun 12 15:04:58.716 ADEL: TFTP: Finished flash:/its/SEPF0B2E577B275.cnf.xml, time 00:00:30 for process 555
2969856: Jun 12 15:05:00.716 ADEL: TFTP: Finished flash:/its/SEPF0B2E577B275.cnf.xml, time 00:00:30 for process 602
Solved! Go to Solution.
06-12-2018 01:26 AM
OK - solved.
As I hoped, there was nothing wrong or incorrect with my config.
The upstream DHCP server was not configured with the correct pool of addresses; it assigned the SIP phone with the address of the VRRP host. Once I resolved that issue the SIP phone registered to CME no problem.
thanks
06-11-2018 11:00 PM
VOICE REGISTER GLOBAL
CONFIG [Version=10.5]
Version 10.5
Mode is cme
Max-pool is 100
Max-dn is 100
Outbound-proxy is enabled and will use global configured value
Security Policy: DEVICE-DEFAULT
Forced Authorization Code Refer is enabled
Source-address is 10.210.5.86 port 5060
Authenticate register
Authenticate realm all
NTP Server Address is 10.210.5.86
NTP Server Mode is: unicast
Time-format is 12
Date-format is M/D/Y
Time-zone is 45
Hold-alert is disabled
Mwi stutter is disabled
Mwi registration for full E.164 is disabled
Forwarding local is enabled
Video is disabled
Camera is disabled
Privacy is enabled
Privacy-on-hold is disabled
Conference hardware is disabled
Dst auto adjust is enabled
start at Apr week 1 day Sun time 02:00
stop at Oct week 8 day Sun time 02:00
Max redirect number is 5
IP QoS DSCP:
ef (the MS 6 bits, 46, in ToS, 0xB8) for media
cs3 (the MS 6 bits, 24, in ToS, 0x60) for signal
af41 (the MS 6 bits, 34, in ToS, 0x88) for video
default (the MS 6 bits, 0, in ToS, 0x0) for service
Telnet Level: 0
Tftp path is flash:/its
Generate text file is disabled
Tftp files are created, current syncinfo 547028220656109A
OS79XX.TXT is not created
timeout interdigit 2
network-locale[0] US (This is the default network locale for this box)
network-locale[1] US
network-locale[2] US
network-locale[3] US
network-locale[4] US
user-locale[0] US (This is the default user locale for this box)
user-locale[1] US
user-locale[2] US
user-locale[3] US
user-locale[4] US
MWI unsolicited notify is disabled
Active registrations : 0
Total SIP phones registered: 0
06-12-2018 01:26 AM
OK - solved.
thanks
