02-01-2012 12:21 AM - edited 03-19-2019 04:19 AM
I am having a problem with Plantronics headsets, the model is plantronics - w01a, and the system version that we are using is CUCM version 7.1.3.10000-11.
I am connecting the headsets to a Cisco 7961 with the following phone load SCCP41.8-5-2SR1S.
The problem is that the headset disconnects from the base station after about 30 seconds.
I have contacted Plantronics, and they confirmed that the headset is working properly.
At the office i have also a UC500 system, on which the headset was giving the same behaviour, but after enabling the hook flash timer the headset did not disconnect again.
But on the CUCM i am still with the same problem.
Any suggestions would be apreciated.
02-01-2012 06:02 AM
Hi Glenn,
I'm sorry but I can't find the model w01a that you are referencing to try
and help troubleshoot this issue. We use lots of CS50's, CS55's, CS70's
some Savi models so maybe you could provide the name of the Headset
if possible
Are you trying to use one of the special APCx cords?
Cheers!
Rob
02-01-2012 11:52 PM
Hi Rob
Thanks for your reply, the Plantronics base is Savi Office WO1 Base, Savi WO100 Headset and Plantronics EHS APC-40.
Glenn
02-02-2012 05:15 AM
Hi Glenn,
Good stuff
I see part of the problem here....the APC-40 is not supported with
the 7961 as shown here;
Installation Instructions for the APC-40
Supported phones are the 7942G, 7945G, 7962G, 7965G, 7975G.
You need a model where you can enable the HHC feature in CUCM which is not available
with the 7941/7961;
Enabling Wireless Headset Hookswitch Control
Access the server administrator with a browser. Select Device>Phone through the drop down menus.
Click "Find" with no selection criteria to obtain a list of all phones
Open the desired phone. Scroll down to "Wireless Headset Hookswitch Control" Set to "Enabled"
Click "Apply". Wait for the dialog box to appear, then reset the phone by clicking the reset button.
So you will need to connect the Savi without the use of the APC-40 and you should
be good to go. You just won't be able to answer calls directly from the headset.
Cheers!
Rob
02-02-2012 08:05 AM
Hi Rob
Thanks again for your reply.
The setting you pointed out are already enabled on Cisco 7942 and 7962 phones, but with the same results.
I have two of these headsets and both are giving me the same result, so i guess it is highly unlikely that both of them are faulty.
Glenn
02-02-2012 09:41 AM
Hi Glenn,
Sorry man, I was going off your original post that referenced a 7961 so my bad!
Did you confirm the base station settings discussed here;
http://headsetplus.com/PDF/savi-ehs.pdf
Cheers!
Rob
02-03-2012 05:25 AM
Hi Rob.
The base station settings are as shown in that document.
Both headsets that i have availably are giving the same behavior. If I dont use tha APC-40 cable the headsets work fine.
I am really at a standstill on this issue.
Glenn
02-03-2012 05:39 AM
02-08-2012 08:51 AM
Hi Rob
Sorry for my late reply, today i managed to upload the phone loads to SCCP42.9-2-3S, but we are still faced with the same situation.
Glenn
04-17-2012 08:43 AM
Hey Glenn,
No worries
I checked the Plantronics knowledge base and this is what is shown;
Headset Turns Off After 45 Seconds
If you are using the EHS (Eectronic Hook Switch) cable, APC-4 or APC-40 with a compatible Cisco desk phone and the headset turns off or drops its link to the base, your phone is not configured correctly. You need the "Electronic Hook Switch" feature on the phone turned on.
This feature can only be activated by your IT or phone system support. Ask them to verify both the headset jack and hook switch features are enabled for your extension. After they make the system side change, reset your phone by unplugging the line cord and re-connecting it.
I know you have checked already but can you please verify once again.
Cheers!
Rob
04-10-2019 07:28 AM
Has anyone found a solution to this issue. We are experiencing the same problem with 7965 phones and Plantronics Savi w740 headsets. The settings in CUCM are enabled as recommended but the issue remains.
10-18-2019 11:41 AM
Did we find a fix for this? I have the Cisco CP 8841 phone with a Plantronics savi w745 wireless headset with a APC-42 that this is happening to as well.
the head set drops from the base after about 45 second to 1 minute while in use
06-10-2021 09:38 AM
I'm using the Mitel Model # IP480, and I'm experimenting the same issue. The headset cuts off after a minute or so. Can you help me. Thank you
10-05-2021 09:43 AM
I'm having a similar issue - I have the Cisco IP 7965 phone with the Plantronics Savi W730 wireless headset. The headset shuts off/disconnects from call after about 20 seconds.
