Problems updating greetings in CUC 11.0.1
pow_der
I am attempting to change greetings for a System Call Handler. When I go to the Call Handler -> Edit -> Greetings -> Standard -> Recordings and push the <Play/Record> button I get the following error:
initMMApplet: InitMMAppletInstance Failed to get instance
As I've gone through different blogs and Cisco guides, I am not having success with resolving this error...
I have the following:
1. Latest Flash  -  I am currently running the latest version of Flash from the Adobe website (version 23)
2. Latest Java  -  I am currently running Java 8 Update 111, freshly downloaded from the Oracle webserver
3. Windows OS  -  Windows 7 Professional 64-Bit
4. Attempted using the following browsers: Chrome 54, Explorer 11, Firefox 49
Is anyone else having this issue and/or know how to work around it?
Thank you in advance...
Jaime Valencia
Have you tried with the Java versions that are listed as supported for your CUC version??
java
if this helps, please rate
I could not locate the version listed: Java 8 Update 97...
Now I cannot find where I saw that... I also see Java 7 Update 51... downloading now
I have now downloaded, installed Java 7 Update 51... removed all other versions, restarted my machine and am still not getting it to work... I do have this error message now:
No support for Java applet: application/x-java-applet;version=1.5
Deepak Rawat
Try ATM and that should work then.
http://www.ciscounitytools.com/Applications/CxN/ATM/ATM.html
Deepak
