11-29-2016 07:54 PM - edited 03-19-2019 11:52 AM
Say you want CUCM and CUC on prem and jabber in the cloud (ie webex messenger). Do you need to have public IP's for CUCM and CUC for this to work?
Solved! Go to Solution.
11-29-2016 09:19 PM
I believe if you are talking about hybrid setup then you are leveraging webex cloud and registering
to CUCM on prem. In this case you would be deploying a Mobile and Remote Setup which
would have Expressway-C and Expressway-E (which would be in the DMZ). Your jabber client
would be talking to Expressway-E and therefore you would not need Public IP for CUCM.
Please rate and mark correct if helpful
Adarsh Chauhan
11-29-2016 09:19 PM
Adarsh Chauhan
