Question on Local calls for Call Manager deployment across states: Planning
johnramz
Beginner
Beginner
we have 3 sites:
Colorado Office area code: 303
California Office area code: 714
Illinois Office: area code: 630
Our DataCenter in Texas: area code: 214
Currently each site has Nortel systems with a PRI DIDs for each one of the Offices.
Network connectity: MPLS VPN for offices and DataCenter
GOALS:
- To deploy Call Manager Server at Data Center and extend it to offices.
- Keep same area codes for all offices
QUESTIONS:
How to keep same are codes if all current PRI circuits at offices would be disconnected and the CM server would centralize all connectiviy from Phone providers?
Is it possible to to have 714 area code phone numbers for California Office in our Texas DataCenter?
If someone takes the time to explain it to me in overview and as much details as considered necessary
John
Chris Deren
Hall of Fame Master Hall of Fame Master
Hall of Fame Master
If you are centralizing your trunking then your only option to have local DIDs is to implement SIP trunking vs. PRI circuits. PRIs connect to central local offices and can only deliver local DIDs.  SIP trunk on the other hand can deliver any numbers. SIP trunks are the facto services these days anyway and besides this type of benfit you will see many others including cost savings.  Keep in mind that for SIP trunking Cisco recommends deployment of Border Element (CUBE) which are simply Cisco gateways (routers) with RTU CUBE licenses.
HTH,
Chris
Chris Deren
Hall of Fame Master
HTH,
Chris
Chris,
Do you know of an online CISCO resource/document that talks about SIP trunks and CISCO gateways for this type of deployment,
Thanks for your quick reply
John
Chris Deren
Hall of Fame Master
The best source is CUCM SRND:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_implementation_design_guides_list.html
which discusses SIP trunking in detail, but there are lots of white papers out there and major service providers i.e. AT&T, Verizon, Level3, XO, CenturyLink, Sprint all have these available, just search their sites.
HTH, please rate all useful posts!
Chris
Thanks Chris for taking your time to reply.
Recognize Your Peers
