Showing results forĀ
Search instead forĀ
Did you mean:Ā
Question Regarding Call transfer
dimple mujoo
If there is a call coming from PSTN to reception and person on reception transfers call to another personā€™s cell phone , the person on cell phone gets reception number instead of original calling Number.
Is it even possible to present the original calling number. Customer is having CME
C2900 Software (C2900-UNIVERSALK9-M), Version 15.2(2)T1
Thank you
7 Replies 7
Nadeem Ahmed
Hello dimple
What is the exact cal-flow ?
Also can you please try configuring under telephony service
Calling-number initiator
And check if this works
Br, Nadeem Please rate all useful post.
Call is coming from PSTN to a DID and being trannsfereed to PSTN number again.
Phone A 905 894 XXXX calling phone B 905 595 XXXX and from their transferred to 905 819 XXXX . the person on
905 819 XXXX gets calling number 905 595 XXXX but wants to see 905 894 XXXX instead.
is this the topology calling from on PRI?
TELCO----PRI----->CME----PRI---TECLO
also try the method which i have suggested under Telephony-Service configuring Calling number initiator.
the calling-number       initiator can be used to preserve the caller ID of the original       calling party
Br,
Nadeem
Sorry that didn't work.
Can you please confirm the topology is this correct which i mentioned?
Call-flow-Topology
Br,
Nadeem
yes that's right..
interface Serial0/0/0:23
no ip address
encapsulation hdlc
isdn switch-type primary-ni
isdn incoming-voice voice
isdn map address ^011* plan unknown type unknown
isdn supp-service name calling
no isdn outgoing ie redirecting-number
no cdp enable
telephony-service
max-ephones 42
max-dn 200
transfer-system full-consult
transfer-pattern .......
transfer-pattern ..........
transfer-pattern ...........
did you tried to enable the isdn outgoing ie redirecting-number on Serial Interface, as of now its disable.
Br,
Nadeem
