Remote Call Forwarding
Mike Matoska
I have a Hunt Pilot number and a Line Group and Hunt List created with 1 member in the Hunt List, Question is Can that one member be call forward external.
It is a VG Analog port but I also try a Cisco Device also a  member of the hunt list it will not follow the Forwarding
Jaime Valencia
Call forward settings for the line group members are ignored when the call comes from a hunt pilot, the only option is SNR and the remote destination would also ring.
java
if this helps, please rate
As Jaime pointed out, when calls are coming from the hunt pilot, the forward setting on the line will be disregarded. If you need to forward the calls, it needs to be set on the Hunt Pilot or a SNR should be used.
Response Signature
