Report for IVR usage
fishizza1
Is there a way to generate a report on IVR usage for a number?  Historically our mainline went directly to an operator who routed calls manually.  Recently we put a recording in with a few IVR options to better help callers self-serve to get to the right department.  Some folks here are not convinced that outside callers actually use it so if there is a way to show statistics on this that would be great.  We are on CUCM 12.0.1
Thanks!
Rob Huffman
Hi there,
If you are running Unity Connection have you tried looking at the built-in Call Handler Traffic Report?
Via> Unity Connection Serviceability> Tools> Reports> Call Handler Traffic Report
It will provide all the Key press activity/routing info. to prove/disprove the callers usage.
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/10x/serv_administration/guide/10xcucservagx/10xcucservag050.html
Cheers!
Rob
Jaime Valencia
And exactly what are you using for the IVR?
java
if this helps, please rate
Sorry for such a slow response I didn't get notified of a reply to this.
It is being used when people call our mainline to get routed to the appropriate department.  We have never used IVR in any fashion before so management is curious about how outside callers are using it.
Rob Huffman
Hi there,
Cheers!
Rob
I will check this out
