reserve a Dial-peer to a specific DN
omanetcisco
I have an ISR 4321 router with a 4-port FXO card, two of these ports are used for GSM calls, my goal is to define one of these ports so that it is only used when a specific DN makes a call to a GSM number , and the other can be used with the rest of the DNs when they make calls to GSM numbers. Can I use the COR list to do this.
Best regards.
Chris Deren
Is this CUCM or CME deployment?
You can use dial peer groups (DPG) to match inbound dial peer based on for example answer-address and then match the outbound dial-peer via the DPG pointer.
Hi sir,
This is a CME deployment.
