Reset Gateway on UCM
I need to configure the caller ID DN field on my UCM (running software 8.0.3.20000-2). I know that after saving the configuration I need to hit the reset button to have the change effective, and i know also that this will drop all calls (if any). How long will the outage be? I mean, after hitting the reset button, when will calls work again?
Thx.
Directly , usually it don't take more than 5 seconds.
Amer
