Ring No Answer in CME
allwyn.reuben
how to increase the "Ring No Answer" value parameter for a specific IP Phone (cisco 7940/60) in Call Manager Express..
When some one calls me im able to hear only 3 rings in my phone and after that gots disconnected.. want to increase it to 5 or 6 rings.. where to do that in CME..
Allwyn Reuben
Vishal Gogia
Hi Allwyn,
It is configured under the same command where you set call-forward noan .
You just have to specify timeout after entering the number. See this:
S324AbingdonCME(config-ephone-dn)#call-forward noan 555 ?
  timeout  Ringing no answer timeout duration
Hope this helps.
ATB
Vishal
Vishal Gogia
Hi Allwyn,
Hope this helps.
ATB
Vishal
Hi Vishal,
Thank you very much,, It works.. is there any option we can roll out this for entire IP Phones in our environment. we have 70+ phones..or do we need to do it manually for each one.
Allwyn Reuben
If you had configured ephone-dn-template, that is best practice, you would be able to apply the change in seconds.
You you had not, do it now.
Vishal Gogia
Glad that it worked.
The only parameter that I can think of is "timeouts ringing" and "timeouts busy" in telephony service.
S324AbingdonCME(config-telephony)#timeouts ringing ?
  <5-60000>  seconds
S324AbingdonCME(config-telephony)#timeouts busy ?
  <0-30>  seconds
We can play with these two params to see if this works. Make sure you do the following after applying this command:
S324AbingdonCME(config-telephony)#no create cnf-files
S324AbingdonCME(config-telephony)#create cnf-files
Then reset 1 of the phones to see if the changes take effect. If it does, its a WIN WIN task. If not, we have to use the manual way instead.
Vishal
