Separate Voice mail messages for internal and External Numbers
shaharshad
Hi All,
Can you please guide me to step up separate voice mail messages for Internal & External number / users for a single user. I don't have any test environment that's why bit more careful.
Thanking in advance.
Arshad
Go to Edit > Greetings on one of the users on Unity Connection, choose the Internal greeting and enable it. Then try calling this extension from an internal phone and later from an external phone to see which greetings are played. The checks from the first link that i shared in my last post need to be looked into as well.
Manish
5 Replies 5
Manish Gogna
Hi Arshad,
You can setup Internal greeting as explained in the following post and doc
https://supportforums.cisco.com/discussion/11881681/unity-connection-86-and-internal-greetings
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/7x/user/guide/assistant/7xcucugasstx/7xcucugasst080.html#wp1012933
Manish
Thanks I have seen this already but a little bit confuse. Actually I want to test it initially on one user and later to other. Can you explain it to me plz?.
Manish
Thanks Manish, that Worked :)
Good to know that , thanks for updating the post.
Manish
