services url does not work during failover, all other services works
solomonthuo
hi
i have configured load-balancing on CSM and also configured a virtual IP for all URLs (information, directory, services & authentication) on the CCM (UCM 7.1.3). The problem is that the services button do not work while all other URLs work when publisher is down. if i set the services URL to the subscriber IP it only works when  the publisher is up. but if i shut the publisher and configure the services url manually, it doesnt work still. could someone assist.
regards
Solomon
htluo
Level 9
Level 9
Have you configured your CSM properly so it can detects the HTTP down on CUCM?
What did you mean by "services button do not work while all other URLs work"?  What other URLs were you talking about?
Thanks!
Michael
http://htluo.blogspot.com
hi michael
On the CSM i have allowed port 8080 since all CCM URLs seems to have that port. I mean the directory url, information & authentication urls  works well, when i press the services button, the phone just shows requesting. some background info, i have pub & sub. i had configured DNS failover but noticed its taking ages to connect to the subscriber when i take down the publisher. After configuring the CSM, i shutdown the ports where publisher is connected and this is when i notice the services URL doesn't respond. Do i need to allow other ports on the CSM?
thanks
solomon
Have you configure your CSM to proble the port 8080 on CUCM?  So it'll know that port was down and direct the traffic to another server?
Thanks!
Michael
Hi Michael
My configs are as follows:
natpool IPT      V.V.V.V  V.V.V.V netmask 255.255.255.0
probe IPT_TCP tcp
  interval 7
  retries 1
  failed 3
  open 1
  port 8080
serverfarm CISCO_IPT
  nat server
  nat client IPT
  description cisco IPT
  real X.X.X.X
   health probe IPT_TCP
   inservice
  real Y.Y.Y.Y
   inservice
vserver CISCOPH_IPT
  virtual V.V.V.V any
  sticky 1 group 2
  replicate csrp sticky
  replicate csrp connection
  persistent rebalance
  inservice
