02-16-2012 01:21 PM - edited 03-19-2019 04:25 AM
I would like to configure voicemail accounts with a minimum credential length of 0 to accomodate voicemail migrations, but it doesn't appear to allow for anything less than 1. Is there a way to do this?
Solved! Go to Solution.
02-16-2012 01:54 PM
I never tried setting the such a policy, but if the intent is to not have a PIN, you can check the "Skip PIN When Calling From a Known Extension" checkbox on the user page.
HTH,
Chris
02-16-2012 01:54 PM
HTH,
Chris
02-16-2012 02:14 PM
Thanks, Chris. That did the trick. A bit different than with the original Unity (I prefer the old way better), but it seems to do the trick as long as I can also select to force the user to set a pin at next login.
