Setting up ACD-AA Script
I'm stuck trying to configure acd-aa script version 3.0.0.2 on a CME version 12.4(24)T, I follow the configuration guide of others routers on this forum but don't get what is missing.  I don't have a hunt-group configured cause there is only one operator, the operator extension is 202, and this are the lines configured:
application
service aa flash:app-b-acd-aa-3.0.0.2.tcl
  paramspace english index 1
  param number-of-hunt-grps 1
  param handoff-string aa
  param dial-by-extension-option 1
  paramspace english language en
  param aa-pilot 220
  paramspace english location flash:
  param second-greeting-time 30
  param welcome-prompt _bacd_welcome.au
  param call-retry-timer 15
  param max-time-call-retry 700
  param service-name queue
service queue flash:app-b-acd-3.0.0.2.tcl
  param aa-hunt 202
  param queue-manager-debugs 1
interface Loopback0
ip address 172.16.32.32 255.255.255.255
dial-peer voice 220 voip
service aa
destination-pattern 220
session target ipv4:172.16.32.32
incoming called-number 220
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
When I dial pilot extension 220, I get an error tone, if you got this application running, please check for the lines above to check on what I'm wrong.
paolo bevilacqua
Take "debug voice application script" with "term mon".And aa-hunt under queue, must end with a digit.
paolo bevilacqua
First of all, thanks for your answer Paolo, I made what you said and there are no debug messages, when I dial pilot number I get a busy tone, this is the ephone-dn configured, something is missing??
ephone-dn 25
number 220
label AA Pilot Number
application aa
For your other comment, I made the change and now it looks like this, is it right??
  param aa-hunt1 202
I'm trying to understand how it works, and I'm sure I'm not doing something cause I haven't found how to do it, if you have an idea where to look for, I will appreciate for your help.
Common Paolo, I still need assistant, if you have the time it will be great if you give me a hand.
