SIP/2.0 407 Proxy Authentication Required
aniket-raut
Hello All,
I am facing issue with Incoming calls from Carrier. Can someone help what below messages means ?
4671: *Dec 16 14:38:25.601: //224/3DF0AC64818D/CUBE_VT/SIP/Msg/ccsipDisplayMsg:
Received: SIP UDP message from 10.5.70.X:5060 to 10.164.203.XXX:5060
Call-ID: 3DF1E4B4-BAF211EF-8193C1F4-89C5F81F@10.164.203.222
Via: SIP/2.0/UDP 10.164.203.XXX:5060;received=10.164.203.XXX;branch=z9hG4bK53C00
To: <sip:8024@ka.ims.airtel.in>;tag=6759465e-67603a462a0c348d
From: "Unavailable" <sip:+918976817XXX@ka.ims.airtel.in>;tag=3F5A24-9C
CSeq: 101 INVITE
Date: Mon, 16 Dec 2024 14:33:42 GMT
Warning: 399 kka57.org "IP association no match, user not registered"
Content-Length: 0
Timestamp: 3817204705601
UTC Timestamp:3817204705601
Source Filename: Inbound Call v3.0
John Dow
I think you need to check your settings and the settings Carrier's, this sip message most likely about the Carrier is not waiting for messages from you from your IP. After 407, if everything is fine, the Carrier should send REGISTERED as a result.
If you share you router configuration, minus any sensitive info we might be able to help you. Please put it in a text file and attached that to your answer.
Response Signature
