SIP Incoming/Outgoing Fax Not Working
Mustain
Hi Good People,
Please help me to solve my problem. I have a CUBE that works fine for Voice traffic, and now I'm configuring the T38 protocol to enable the fax service. The problem is FAX can only send/receive faxes if the others are running on SIP too. But if a different side is running on E1, the fax will not work.
I've gathered the debug output from CUBE, but still don't understand what's going on.
The call flow is: ITSP <--> SIP <--> CUBE <--> CUCM <--> MGCP <--> VG224 <--> FAX Machines.
Thanks in advance.
Mustain
The problem was solved. I tried to uncheck the MTP option on the CUCM SIP Trunk. And some things have been adjusted on the ITSP side such as Codecs, etc.
10 Replies 10
BalajiSivaraj49175
SIP message may instruct that following threshold in the configuration
Hi @BalajiSivaraj49175
Thank you for your comment, would you like to provide an appropriate reference for your comment?
BalajiSivaraj49175
rules for message communication and sampling for channel information.
T.38 - Delay<1000ms, Jitter<300ms, Packet loss should be NONE unless T.38 with redundancy.
Passthrough - Delay<1000ms, Jitter<30ms, Packet loss should be NONE.
Protocol Based switchover - This is standard based.
NSE Based switchover - This is proprietary and works only between Cisco voice gateways.
BalajiSivaraj49175
BalajiSivaraj49175
Can find the referance SIP communication message between the devices(FAX)
https://www.cisco.com/c/en/us/support/docs/voice/session-initiation-protocol-sip/118647-technote-sip-00.html
BalajiSivaraj49175
Debug message useful referaance to capture SIP message troubleshoot issue
BalajiSivaraj49175
This are different messages communicate between the devises.
BalajiSivaraj49175
GW and CUCM message communication frequency message communication when debug this infoCapture25.JPG
I've tried this, but it still doesn't solve my problem
Mustain
