403 Forbidden on Inbound Calls
mumbles202
Level 5
Level 5
Working on a new install of CUCM cube. ISR 4300 as the gateway.  It's a pre-existing CUCM environment with a MGCP gateway is current PsTN access. Setup a trunk from CUBE to CUCM, CSS for the trunk includes the partition with the internal DNs, and DNA shows inbound calls should ring the extension. Outbound calls through the CUBE are working but inbound I seem to be getting a 403 from CUCM. I can upload the debug from the gateway but wondering if something I should be looking at on either the CUCM or VG side. I can post up the configuration from the VG as well.
OK that makes sense.  You can enable the proxy globally in voice service, but disable it on individual dial peers.
dial-peer voice 11 voip
 no voice-class sip outbound-proxy
40 Replies 40
Post your configuration from VG.
Response Signature
If you are truly getting a 403 from CUCM the likely cause could be that you have not bound the dial peers to the proper interface so that the SBC (Cube) is sourcing the inbound calls from the interface that is facing your ITSP. As the trunk in CM is set with an IP to the SBC it would only allow traffic coming from that specific IP. Any other IP(s) would be dropped as part of the built in security in CM.
Response Signature
mumbles202
Level 5
Level 5
Here's the configuration from the gateway.  I placed an inbound call to 8888888888 for example.
Building configuration...
Current configuration : 5507 bytes
! Last configuration change at 22:59:42 UTC Thu Feb 11 2021
version 16.6
platform qfp utilization monitor load 80
no platform punt-keepalive disable-kernel-core
hostname Router
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
no aaa new-model
subscriber templating
voice service voip
 ip address trusted list
  ipv4 172.27.32.5
  ipv4 172.27.32.6
  ipv4 12.12.12.12
  ipv4 8.1.1.1
 mode border-element
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 supplementary-service h450.12
 fax protocol t38 version 0 ls-redundancy 2 hs-redundancy 0 fallback pass-through g711ulaw
 h323
  h225 timeout ntf 50
  h225 display-ie ccm-compatible
  call start slow
  call preserve
 sip
  outbound-proxy ipv4:8.1.1.1
voice class codec 1
 codec preference 1 g711ulaw
 codec preference 2 g729r8
voice class h323 1
  h225 timeout tcp establish 3
voice class server-group 1
 ipv4 172.27.32.5 preference 1
 ipv4 172.27.32.6 preference 2
voice-card 0/1
 no watchdog
diagnostic bootup level minimal
username admin privilege 15 secret 5
redundancy
 mode none
interface GigabitEthernet0/0/0
 ip address dhcp
 negotiation auto
interface GigabitEthernet0/0/1
 ip address 172.27.32.8 255.255.255.0
 negotiation auto
 h323-gateway voip interface
 h323-gateway voip bind srcaddr 172.27.32.8
interface Service-Engine0/1/0
 vrf forwarding Mgmt-intf
 no ip address
 negotiation auto
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http client source-interface GigabitEthernet0/0/1
control-plane
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
sccp local GigabitEthernet0/0/1
sccp ccm 172.27.32.10 identifier 1 version 7.0
sccp ccm 172.27.32.11 identifier 2 version 7.0
sccp
sccp ccm group 1
 associate ccm 1 priority 1
 associate ccm 2 priority 2
 switchover method immediate
dspfarm profile 2 transcode
 associate application CUBE
 shutdown
dspfarm profile 1 mtp
 codec g711ulaw
 codec pass-through
 maximum sessions software 200
dial-peer voice 1 voip
 description incoming calls from ITSP
 session protocol sipv2
 incoming called-number 99999999..
 voice-class codec 1
 voice-class sip bind control source-interface GigabitEthernet0/0/0
 voice-class sip bind media source-interface GigabitEthernet0/0/0
 dtmf-relay rtp-nte digit-drop
dial-peer voice 2 voip
 incoming called-number 8888888888
 voice-class codec 1
dial-peer voice 5 voip
 description incoming calls from CUCM
 voice-class codec 1
dial-peer voice 10 voip
 description Outgoing calls to CUCM
 destination-pattern 99999999..
 session server-group 1
 voice-class codec 1
 destination-pattern 8888888888
 voice-class sip options-keepalive
 voice-class sip bind control source-interface GigabitEthernet0/0/1
 voice-class sip bind media source-interface GigabitEthernet0/0/1
 voice-class codec 1
 fax-relay sg3-to-g3
 fax rate 14400
 fax nsf 000000
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
dial-peer voice 15 voip
 description Outgoing calls to ITSP
 destination-pattern [2-9]......
 session target ipv4:12.12.12.12
 voice-class codec 1
dial-peer voice 16 voip
 destination-pattern [2-9]..[2-9]......
 voice-class codec 1
dial-peer voice 17 voip
 destination-pattern 00T
 session target sip-server
 voice-class codec 1
dial-peer voice 18 voip
 destination-pattern 123456789
 voice-class codec 1
gateway
 timer receive-rtp 1200
line con 0
 transport input none
 stopbits 1
line aux 0
 stopbits 1
line vty 0 4
 login
wsma agent exec
wsma agent config
wsma agent filesys
wsma agent notify
end
Router#
Router#
Router#
Suggest you make these changes.
voice service voip
 no allow-connections h323 to h323 !If you are not using H323 in CUCM for this specific VGW this is not needed
 no allow-connections h323 to sip !If you are not using H323 in CUCM for this specific VGW this is not needed
 no allow-connections sip to h323 !If you are not using H323 in CUCM for this specific VGW this is not needed
address-hiding
voice class uri ITSP sip
 host ipv4:12.12.12.12
 host ipv4:8.1.1.1
voice class uri CUCM sip
 host ipv4:172.27.32.5
 host ipv4:172.27.32.6
voice class e164-pattern-map 1
 description E164 Pattern Map for called number to CUCM
  e164 8888888888
  e164 99999999..
voice class e164-pattern-map 2000
 description E164 Pattern Map for called number to ITSP
  e164 0T
  e164 [2-9]......
  e164 [2-9]..[2-9]......
 ipv4 172.27.32.5 preference 2
 description CUCM server group
voice class server-group 2000
 ipv4 12.12.12.12 preference 1
ipv4 8.1.1.1 preference 2 description ITSP server group ! voice class sip-options-keepalive 1 description Used for Server Group SIP OPTIONS PING ! interface GigabitEthernet0/0/1 no h323-gateway voip bind srcaddr 172.27.32.8 !If you are not using H323 in CUCM for this specific VGW this is not needed no h323-gateway voip interface !If you are not using H323 in CUCM for this specific VGW this is not needed ! dial-peer voice 1 voip description Incoming calls from ITSP session protocol sipv2 incoming uri via ITSP voice-class codec 1 voice-class sip bind control source-interface GigabitEthernet0/0/0 voice-class sip bind media source-interface GigabitEthernet0/0/0 dtmf-relay rtp-nte digit-drop !Not sure what dtmf digit-drop means, but likely not a factor in your issue. no vad ! no dial-peer voice 2 voip ! dial-peer voice 5 voip description Incoming calls from CUCM session protocol sipv2 incoming uri via CUCM voice-class codec 1 voice-class sip bind control source-interface GigabitEthernet0/0/1 voice-class sip bind media source-interface GigabitEthernet0/0/1 dtmf-relay rtp-nte sip-kpml no vad ! no dial-peer voice 10 voip ! dial-peer voice 11 voip description Outgoing calls to CUCM session protocol sipv2 session server-group 1 destination e164-pattern-map 1 voice-class codec 1 voice-class sip options-keepalive profile 1 voice-class sip bind control source-interface GigabitEthernet0/0/1 voice-class sip bind media source-interface GigabitEthernet0/0/1 fax-relay sg3-to-g3 fax rate 14400 fax nsf 000000 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none dtmf-relay rtp-nte sip-kpml no vad ! dial-peer voice 15 voip description Outgoing calls to ITSP session protocol sipv2 session server-group 2000 destination e164-pattern-map 2000 voice-class codec 1 voice-class sip options-keepalive profile 1 voice-class sip bind control source-interface GigabitEthernet0/0/0 voice-class sip bind media source-interface GigabitEthernet0/0/0 dtmf-relay rtp-nte digit-drop !Not sure what dtmf digit-drop means, but likely not a factor in your issue. no vad ! no dial-peer voice 16 voip ! no dial-peer voice 17 voip ! no dial-peer voice 18 voip
Response Signature
Thanks for rhe detailed chsnges. I'll give them a try this morning. Would there be an issue if CUCM isn't currently setup for E164 or URI?
None of the configuration I suggested have anything to do with E164 or URI dialing, even if the names of the configuration elements might lead you to believe so. Recommend you to have a look at this excellent document about IOS call routing. In Depth Explanation of Cisco IOS and IOS-XE Call Routing - Cisco It is an absolute classic.
Response Signature
Thanks for the link.  I'll be sure to give it a read this weekend.  I made the recommended changes and, while it does take bit longer to get the error, ultimately I'm still getting the 403 Forbidden.  The carrier is sending 10 digits, I have 4 as significant in the trunk and my DN is just the last 4 of the inbound called number.
This is a debug I gathered earlier today.  Calling number being 7777777777 and called number was 8888888888:
Feb 12 17:25:49.141: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:8888888888@4.4.4.4:5061 SIP/2.0
Via: SIP/2.0/UDP 12.12.12.12:5060;rport;branch=z9hG4bK+a8a07ceb9d47da9278d793788c5e00241+sip+1+c0ac149e
From: "WIRELESS CALLER" <sip:7777777777@8.1.1.1>;tag=12.12.12.12+1+80c694e4+f23198f4
To: <sip:8888888888@8.1.1.1>
CSeq: 246657541 INVITE
Expires: 180
Content-Length: 173
Call-Info: <sip:12.12.12.12:5060>;method="NOTIFY;Event=telephone-event;Duration=2000"
Supported: resource-priority,siprec, 100rel
Contact: <sip:1f42c7522f69bc809038655ca01aa785@12.12.12.12:5060>
Content-Type: application/sdp
Allow-Events: message-summary, refer, dialog, line-seize, presence, call-info, as-feature-event, calling-name, ua-profile
Call-ID: 0gQAAC8WAAACBAAALxYAAL8f1CQ+6xdMzRliUllrT+cSqoHDGVIOT03kwVWF5Q5f@12.12.12.12
Organization: MSW
Max-Forwards: 67
Accept: application/sdp, application/dtmf-relay
v=0
o=- 125933255392586 125933255392586 IN IP4 12.12.12.12
s=-
c=IN IP4 12.12.12.12
t=0 0
m=audio 63394 RTP/AVP 0 101
a=rtpmap:101 telephone-event/8000
a=ptime:20
Feb 12 17:25:49.144: //-1/2ECF37058B7D/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=7777777777
   ----- ccCallInfo IE subfields -----
   cisco-ani=7777777777
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=8888888888
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFFFFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Feb 12 17:25:49.144: //-1/2ECF37058B7D/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x7F66F2101DB0, Call Info(
   Calling Number=7777777777,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=8888888888(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=1, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=3972
Feb 12 17:25:49.145: //-1/2ECF37058B7D/CCAPI/ccCheckClipClir:
   In: Calling Number=7777777777(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=7777777777(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Feb 12 17:25:49.145: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Feb 12 17:25:49.145: :cc_get_feature_vsa malloc success
Feb 12 17:25:49.145:  cc_get_feature_vsa count is 1
Feb 12 17:25:49.145: :FEATURE_VSA attributes are: feature_name:0,feature_time:140080145090892,feature_id:116
Feb 12 17:25:49.145: //3972/2ECF37058B7D/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=7777777777(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=8888888888(TON=Unknown, NPI=Unknown))
Feb 12 17:25:49.146: //3972/2ECF37058B7D/CCAPI/cc_process_call_setup_ind:
   Event=0x7F66F34BF968
Feb 12 17:25:49.146: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 8888888888
Feb 12 17:25:49.146: //3972/2ECF37058B7D/CCAPI/ccCallSetContext:
   Context=0x7F66FB371F00
   >>>>CCAPI handed cid 3972 with tag 1 to app "_ManagedAppProcess_Default"
Feb 12 17:25:49.146: //3972/2ECF37058B7D/CCAPI/ccCallProceeding:
Feb 12 17:25:49.147: //3972/2ECF37058B7D/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=11, Params=0x7F66FB373670, Progress Indication=NULL(0)
Feb 12 17:25:49.147: //3972/2ECF37058B7D/CCAPI/ccCheckClipClir:
   Destination Pattern=, Called Number=8888888888, Digit Strip=FALSE
   Redirect Number=, Display Info=WIRELESS CALLER
   Account Number=7777777777, Final Destination Flag=TRUE,
   Guid=2ECF3705-6C8E-11EB-8B7D-F0E1EB326086, Outgoing Dial-peer=11
Feb 12 17:25:49.147: //3972/2ECF37058B7D/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=8888888888
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Feb 12 17:25:49.148: //3972/2ECF37058B7D/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x7F66F2101DB0, Interface Type=3, Destination=, Mode=0x0,
   Call Params(Calling Number=7777777777,(Calling Name=WIRELESS CALLER)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=8888888888(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=11, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Feb 12 17:25:49.148: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Feb 12 17:25:49.148: :cc_get_feature_vsa malloc success
Feb 12 17:25:49.148:  cc_get_feature_vsa count is 2
Feb 12 17:25:49.149: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Feb 12 17:25:49.149: :FEATURE_VSA attributes are: feature_name:0,feature_time:140080145090668,feature_id:117
Feb 12 17:25:49.149: //3972/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Feb 12 17:25:49.149: cc_api_get_xcode_stream : 4981
Feb 12 17:25:49.149: //3972/2ECF37058B7D/CCAPI/cc_api_event_indication:
   Event=101, Call Id=3972
   Event Is Sent To Conferenced SPI(s) Directly
Feb 12 17:25:49.150: //3973/2ECF37058B7D/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
Feb 12 17:25:49.150: //3973/2ECF37058B7D/CCAPI/ccCallSetContext:
   Context=0x7F66FB3735F0
Feb 12 17:25:49.150: //3972/2ECF37058B7D/CCAPI/ccSaveDialpeerTag:
Feb 12 17:25:49.150: //3973/2ECF37058B7D/CCAPI/ccGetMediaClassTag:
   media class tag 0
Feb 12 17:25:49.150: //3973/2ECF37058B7D/CCAPI/ccSetMediaclassIp2ipTags:
   media class tags set: NR 0, ASP 0
Feb 12 17:25:49.150: //3972/2ECF37058B7D/CCAPI/ccGetMediaClassTag:
   media class tag 0
Feb 12 17:25:49.150: //3972/2ECF37058B7D/CCAPI/ccSetMediaclassIp2ipTags:
Feb 12 17:25:49.151: //3973/2ECF37058B7D/CCAPI/ccGet_xc_nr_asp_info:
   media class tags: NR 0, ASP 0
Feb 12 17:25:49.151: //3972/2ECF37058B7D/CCAPI/ccGet_xc_nr_asp_info:
Feb 12 17:25:49.151: //-1/xxxxxxxxxxxx/CCAPI/cc_is_cng_fax_detect_active:
   Call Id 3972
Feb 12 17:25:49.151: //3973/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Feb 12 17:25:49.151: cc_api_get_xcode_stream : 4981
Feb 12 17:25:49.152: //3973/2ECF37058B7D/CCAPI/cc_api_call_proceeding:
   Interface=0x7F66F2101DB0, Progress Indication=NULL(0)
Feb 12 17:25:49.152: //3973/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Feb 12 17:25:49.153: cc_api_get_xcode_stream : 4981
Feb 12 17:25:49.153: //3973/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Feb 12 17:25:49.153: //3972/2ECF37058B7D/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Fri, 12 Feb 2021 17:25:49 GMT
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-16.6.4
Session-ID: 00000000000000000000000000000000;remote=1e25b1942e9a5231b6b6ffdfce05bdfb
Content-Length: 0
Feb 12 17:25:49.154: //3973/2ECF37058B7D/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:8888888888@172.27.32.11 SIP/2.0
Via: SIP/2.0/UDP 172.27.32.8:5060;branch=z9hG4bK67C189D
Remote-Party-ID: "WIRELESS CALLER" <sip:7777777777@172.27.32.8>;party=calling;screen=no;privacy=off
From: "WIRELESS CALLER" <sip:7777777777@8.1.1.1>;tag=495F71F-1EA1
To: <sip:8888888888@172.27.32.11>
Call-ID: 2ED0BD69-6C8E11EB-8B83F0E1-EB326086@172.27.32.8
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 0785331973-1821250027-2340286689-3945947270
User-Agent: Cisco-SIPGateway/IOS-16.6.4
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1613150749
Contact: <sip:7777777777@172.27.32.8:5060>
Expires: 300
Allow-Events: kpml, telephone-event
Max-Forwards: 66
Session-ID: 1e25b1942e9a5231b6b6ffdfce05bdfb;remote=00000000000000000000000000000000
Content-Disposition: session;handling=required
Content-Length: 246
v=0
o=CiscoSystemsSIP-GW-UserAgent 3560 2972 IN IP4 172.27.32.8
s=SIP Call
c=IN IP4 172.27.32.8
t=0 0
m=audio 8232 RTP/AVP 0 101
a=rtpmap:0 PCMU/8000
a=fmtp:101 0-15
a=ptime:20
Feb 12 17:25:49.653: //3973/2ECF37058B7D/SIP/Msg/ccsipDisplayMsg:
Sent:
Min-SE:  1800
CSeq: 101 INVITE
Expires: 300
Max-Forwards: 66
Content-Length: 246
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-15
a=ptime:20
Feb 12 17:25:50.653: //3973/2ECF37058B7D/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Fri, 12 Feb 2021 17:25:50 GMT
Min-SE:  1800
CSeq: 101 INVITE
Timestamp: 1613150750
Expires: 300
Max-Forwards: 66
Content-Length: 246
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-15
a=ptime:20
Feb 12 17:25:52.654: //3973/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Feb 12 17:25:52.654: cc_api_get_xcode_stream : 4981
Feb 12 17:25:52.655: //3973/2ECF37058B7D/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:8888888888@172.27.32.10 SIP/2.0
Via: SIP/2.0/UDP 172.27.32.8:5060;branch=z9hG4bK67D241A
From: "WIRELESS CALLER" <sip:7777777777@8.1.1.1>;tag=49604CC-1171
To: <sip:8888888888@172.27.32.10>
Date: Fri, 12 Feb 2021 17:25:52 GMT
Min-SE:  1800
CSeq: 102 INVITE
Timestamp: 1613150752
Expires: 300
Max-Forwards: 66
Content-Length: 246
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-15
a=ptime:20
Feb 12 17:25:53.155: //3973/2ECF37058B7D/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Fri, 12 Feb 2021 17:25:53 GMT
Min-SE:  1800
CSeq: 102 INVITE
Timestamp: 1613150753
Expires: 300
Max-Forwards: 66
Content-Length: 246
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-15
a=ptime:20
Feb 12 17:25:54.155: //3973/2ECF37058B7D/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Fri, 12 Feb 2021 17:25:54 GMT
Min-SE:  1800
CSeq: 102 INVITE
Timestamp: 1613150754
Expires: 300
Max-Forwards: 66
Content-Length: 246
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-15
a=ptime:20
Feb 12 17:25:56.154: //3973/2ECF37058B7D/CCAPI/cc_api_call_disconnected:
   Cause Value=102, Interface=0x7F66F2101DB0, Call Id=3973
   Call Entry(Responsed=TRUE, Cause Value=102, Retry Count=0)
Feb 12 17:25:56.154: //3972/2ECF37058B7D/CCAPI/ccCallReleaseResources:
   release reserved xcoding resource.
Feb 12 17:25:56.155: //3973/2ECF37058B7D/CCAPI/ccCallSetAAA_Accounting:
   Accounting=1, Call Id=3973
Feb 12 17:25:56.155: //3973/2ECF37058B7D/CCAPI/ccCallDisconnect:
   Cause Value=102, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=102)
   Cause Value=102, Call Entry(Responsed=TRUE, Cause Value=102)
Feb 12 17:25:56.155: //3973/2ECF37058B7D/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x7F66F2101DB0, Tag=0x0, Call Id=3973,
   Call Entry(Disconnect Cause=102, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
Feb 12 17:25:56.156: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Feb 12 17:25:56.156: :cc_free_feature_vsa freeing 7F66F349C860
Feb 12 17:25:56.156:  vsacount in free is 1
Feb 12 17:25:56.156: //3972/2ECF37058B7D/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=15, Params=0x7F66FB374D60, Progress Indication=NULL(0)
Feb 12 17:25:56.156: //3972/2ECF37058B7D/CCAPI/ccCheckClipClir:
Feb 12 17:25:56.157: //3972/2ECF37058B7D/CCAPI/ccCheckClipClir:
Feb 12 17:25:56.157: //3972/2ECF37058B7D/CCAPI/ccCallSetupRequest:
   Guid=2ECF3705-6C8E-11EB-8B7D-F0E1EB326086, Outgoing Dial-peer=15
Feb 12 17:25:56.157: //3972/2ECF37058B7D/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=8888888888
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Feb 12 17:25:56.158: //3972/2ECF37058B7D/CCAPI/ccIFCallSetupRequestPrivate:
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=15, Call Count On=FALSE,
Feb 12 17:25:56.158: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Feb 12 17:25:56.158: :cc_get_feature_vsa malloc success
Feb 12 17:25:56.158:  cc_get_feature_vsa count is 2
Feb 12 17:25:56.158: :FEATURE_VSA attributes are: feature_name:0,feature_time:140080145090668,feature_id:118
Feb 12 17:25:56.159: //3972/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Feb 12 17:25:56.159: cc_api_get_xcode_stream : 4981
Feb 12 17:25:56.159: //3972/2ECF37058B7D/CCAPI/cc_api_event_indication:
Feb 12 17:25:56.159: //3974/2ECF37058B7D/CCAPI/ccIFCallSetupRequestPrivate:
Feb 12 17:25:56.159: //3974/2ECF37058B7D/CCAPI/ccCallSetContext:
   Context=0x7F66FB374CE0
Feb 12 17:25:56.160: //3972/2ECF37058B7D/CCAPI/ccSaveDialpeerTag:
Feb 12 17:25:56.160: //3974/2ECF37058B7D/CCAPI/ccGetMediaClassTag:
   media class tag 0
Feb 12 17:25:56.160: //3974/2ECF37058B7D/CCAPI/ccSetMediaclassIp2ipTags:
Feb 12 17:25:56.160: //3972/2ECF37058B7D/CCAPI/ccGetMediaClassTag:
   media class tag 0
Feb 12 17:25:56.160: //3972/2ECF37058B7D/CCAPI/ccSetMediaclassIp2ipTags:
Feb 12 17:25:56.160: //3974/2ECF37058B7D/CCAPI/ccGet_xc_nr_asp_info:
Feb 12 17:25:56.160: //3972/2ECF37058B7D/CCAPI/ccGet_xc_nr_asp_info:
Feb 12 17:25:56.161: //-1/xxxxxxxxxxxx/CCAPI/cc_is_cng_fax_detect_active:
   Call Id 3972
Feb 12 17:25:56.161: //3974/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Feb 12 17:25:56.161: cc_api_get_xcode_stream : 4981
Feb 12 17:25:56.161: //3974/2ECF37058B7D/CCAPI/cc_api_call_proceeding:
Feb 12 17:25:56.162: //3974/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Feb 12 17:25:56.162: cc_api_get_xcode_stream : 4981
Feb 12 17:25:56.163: //3974/2ECF37058B7D/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:8888888888@12.12.12.12 SIP/2.0
Via: SIP/2.0/UDP 192.168.1.76:5060;branch=z9hG4bK67E2583
Remote-Party-ID: "WIRELESS CALLER" <sip:7777777777@192.168.1.76>;party=calling;screen=no;privacy=off
From: "WIRELESS CALLER" <sip:7777777777@8.1.1.1>;tag=4961281-7D3
To: <sip:8888888888@12.12.12.12>
Date: Fri, 12 Feb 2021 17:25:56 GMT
Call-ID: 32FE3A8F-6C8E11EB-8B85F0E1-EB326086@192.168.1.76
Min-SE:  1800
CSeq: 101 INVITE
Timestamp: 1613150756
Contact: <sip:7777777777@192.168.1.76:5060>
Expires: 300
Max-Forwards: 66
Content-Length: 246
v=0
o=CiscoSystemsSIP-GW-UserAgent 4406 3079 IN IP4 192.168.1.76
s=SIP Call
c=IN IP4 192.168.1.76
t=0 0
m=audio 8234 RTP/AVP 0 101
a=fmtp:101 0-15
a=ptime:20
Feb 12 17:25:56.168: //3974/2ECF37058B7D/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
To: <sip:8888888888@12.12.12.12>;tag=sip+1+d6820060+a7915ecb
Via: SIP/2.0/UDP 4.4.4.4:5062;received=125.125.125.190;branch=z9hG4bK67E2583
Server: SIP/2.0
Content-Length: 0
Feb 12 17:25:56.173: //3974/2ECF37058B7D/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 403 Forbidden
CSeq: 101 INVITE
Server: SIP/2.0
Content-Length: 0
Contact: <sip:12.12.12.12:5060>
Organization: MSW
Feb 12 17:25:56.174: //3974/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Feb 12 17:25:56.174: cc_api_get_xcode_stream : 4981
Feb 12 17:25:56.174: //3974/2ECF37058B7D/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:8888888888@12.12.12.12 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Session-ID: ;remote=
Content-Length: 0
Feb 12 17:25:56.175: //3974/2ECF37058B7D/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:8888888888@8.1.1.1 SIP/2.0
Via: SIP/2.0/UDP 192.168.1.76:5060;branch=z9hG4bK67F1999
From: "WIRELESS CALLER" <sip:7777777777@8.1.1.1>;tag=496128C-CF7
Min-SE:  1800
CSeq: 102 INVITE
Expires: 300
Max-Forwards: 66
Content-Length: 246
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-15
a=ptime:20
Feb 12 17:25:56.180: //3974/2ECF37058B7D/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 102 INVITE
To: <sip:8888888888@8.1.1.1>;tag=sip+1+d6820060+a8efdb9
Via: SIP/2.0/UDP 4.4.4.4:5062;received=125.125.125.190;branch=z9hG4bK67F1999
Server: SIP/2.0
Content-Length: 0
Feb 12 17:25:56.184: //3974/2ECF37058B7D/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 102 INVITE
Server: SIP/2.0
Content-Length: 0
Organization: MSW
Feb 12 17:25:56.184: //3974/2ECF37058B7D/CCAPI/cc_api_call_disconnected:
   Cause Value=57, Interface=0x7F66F2101DB0, Call Id=3974
   Call Entry(Responsed=TRUE, Cause Value=57, Retry Count=0)
Feb 12 17:25:56.185: //3972/2ECF37058B7D/CCAPI/ccCallReleaseResources:
Feb 12 17:25:56.185: //3974/2ECF37058B7D/CCAPI/ccCallSetAAA_Accounting:
   Accounting=0, Call Id=3974
Feb 12 17:25:56.185: //3974/2ECF37058B7D/CCAPI/ccCallDisconnect:
   Cause Value=57, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=57)
   Cause Value=57, Call Entry(Responsed=TRUE, Cause Value=57)
Feb 12 17:25:56.185: //3974/2ECF37058B7D/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x7F66F2101DB0, Tag=0x0, Call Id=3974,
   Call Entry(Disconnect Cause=57, Voice Class Cause Code=0, Retry Count=0)
Feb 12 17:25:56.186: //3974/2ECF37058B7D/CCAPI/cc_api_call_disconnect_done:
Feb 12 17:25:56.186: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Feb 12 17:25:56.186: :cc_free_feature_vsa freeing 7F66F349C860
Feb 12 17:25:56.186:  vsacount in free is 1
Feb 12 17:25:56.186: //3972/2ECF37058B7D/CCAPI/ccCallDisconnect:
   Cause Value=57, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Feb 12 17:25:56.187: //3974/2ECF37058B7D/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:8888888888@8.1.1.1 SIP/2.0
Max-Forwards: 70
CSeq: 102 ACK
Content-Length: 0
Feb 12 17:25:56.188: //3972/2ECF37058B7D/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <sip:8888888888@8.1.1.1>;tag=496129A-193E
Reason: Q.850;cause=57
Content-Length: 0
Feb 12 17:25:56.223: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:8888888888@4.4.4.4:5061 SIP/2.0
CSeq: 246657541 ACK
Content-Length: 0
Max-Forwards: 67
Feb 12 17:25:56.224: //3972/2ECF37058B7D/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x7F66F2101DB0, Tag=0x0, Call Id=3972,
Feb 12 17:25:56.224: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Feb 12 17:25:56.224: :cc_free_feature_vsa freeing 7F66F349C940
Feb 12 17:25:56.224:  vsacount in free is 0
Feb 12 17:26:00.098: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
OPTIONS sip:172.27.32.8:5060 SIP/2.0
Via: SIP/2.0/TCP 172.27.32.10:5060;branch=z9hG4bK2757c5373c06a0
To: <sip:172.27.32.8>
Date: Fri, 12 Feb 2021 17:26:00 GMT
Call-ID: 5e79c980-261ba28-10cc44-a60a8c0@172.27.32.10
User-Agent: Cisco-CUCM11.5
CSeq: 101 OPTIONS
Contact: <sip:172.27.32.10:5060;transport=tcp>
Max-Forwards: 0
Content-Length: 0
Feb 12 17:26:00.099: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:172.27.32.8>;tag=49621E1-23DB
CSeq: 101 OPTIONS
Content-Length: 373
v=0
o=CiscoSystemsSIP-GW-UserAgent 9457 1672 IN IP4 172.27.32.8
s=SIP Call
t=0 0
m=audio 0 RTP/AVP 18 0 8 9 4 2 15 3
m=image 0 udptl t38
a=T38FaxVersion:0
a=T38MaxBitRate:9600
a=T38FaxRateManagement:transferredTCF
a=T38FaxMaxBuffer:200
a=T38FaxMaxDatagram:320
a=T38FaxUdpEC:t38UDPRedundancy
In the debug output I see these IPs
172.27.32.10 and 172.27.32.11
What is that, is it other CM CPE nodes that you don’t have defined in your gateway server group? If you have more nodes than the two you have defined in the server group and the trunk is setup to run on all nodes you have two options, either you add all the other nodes to the server group or you add the IPs of these to the trusted list in voice service voip. This is to let the gateway know that it should allow VoIP traffic from these nodes.
It also looks like the call is looping back to the ITSP as the outbound dial peer at time in the debug is the one for outbound to the ITSP. That is likely caused by that the destination numbers you had in your old dial peers, and is now in the number group, cause a loop. This is not a good thing, you should take measures to avoid situations where this can occur by having the number routing not overlap. If you do need to keep the overlap you could look at using COR to limit the path the call takes via your dial peers. For for information on this have a look at this document. https://www.cisco.com/c/en/us/support/docs/voice/call-routing-dial-plans/42720-configuring-cor.html
For the number manipulation part, I would advise you to use voice translations in the gateway to transform the called and calling numbers into the format you’d want it in CUCM. Where you assign this depends on what transformations you do. I would have translated both of these on the ingress from the ITSP, aka on the inbound dial peer for calls from PSTN.
Response Signature
Try with these modifications in the gateway and remove any number transformation/modification you might have in CM on the trunk.
voice service voip
  ipv4 172.27.32.10
  ipv4 172.27.32.11
voice translation-rule 10 !Add a 0 (zero) infront of calling number so that it can be called back to without any need to modify the number on then phone. Change to fit your needs.
 rule 1 /\(.*\)/ /0\1/
voice translation-rule 20
 rule 1 /^[89].....\(....\)$/ /\1/ !Match on all 10 digit numbers that starts with 8 or 9 and transform it to keep the last 4. Change to fit your needs.
voice translation-profile PSTN-IN
 translate calling 10
 translate called 20
 translation-profile incoming PSTN-IN
  e164 ^....$
  e164 0T
Response Signature
Thanks for the detailed response. The 2 addresses (.10 and .11) we're actually .5 and
6 from the config above.
I'll review the config of the gateway and make sure there aren't any overlaps as there doesn't need to be for this case.
In your example above, what is the use for translation rule 10? Is it just so users can dial a number that is in there call log with the need to edit it to include the 91 to proceed it?
Yes translation rule 10 is intended for translation of calling number so that the receiver can call back to it without any need for making any manual changes to it on the phones. As you have not shared any real number information or for what country this is for I just used the information at hand and as you had 0T on a dial peer I assumed that this would be how you call out to PSTN. Quite likely you’d need to adopt this to suit your needs.
Response Signature
Understood. This is for US based calling so I can adjust as needed. Thanks
With US based I would think that something along the line with this should do. However no guarantee, it’s free from memory.
rule 1 /\(^[2-9]..[2-9]......$\)/ /91\1/
rule 2 /\(^[2-9]......$\)/ /9\1/
rule 3 /.*/ /9011\0/
Then also change the number in the E164 number map to 9T. You would likely also need to have a translation rule for egress calls to drop the 9.
voice translation-rule 40
 rule 1 /^9\(.*\)/ /\1/
voice translation-profile PSTN-OUT
 translate called 40
 translation-profile outgoing PSTN-OUT
Response Signature
@mumbles202 Any update on this? Have you succeeded to get this to work?
Response Signature
