01-14-2011 04:17 PM - edited 03-19-2019 02:13 AM
Hi all -
New deployment of CUPS 8.0 and CUCM 8.5, have been attempting to fix the following error in CUPS System Configuration Troubleshooter,"Currently SIP Publish is configured on the Cisco Unified Presence server, but not on the Cisco Unified Communications Manager". Found the following two bugs out on Bug Toolkit you may be interested in:
- CSCti19329 Bug Details (appears to be cosmetic at this point)
| You have this bug saved in the following group(s): CUPS . (Bolded group names are subscribed to email notifications.) |
- CSCti19018 Bug Details (in testing for the previous error, I toggled the checkbox and did not restart the Presence Engine. I did after finding this bug.)
Hope this helps someone else troubleshooting same! Sincerely, Ginger
03-18-2011 03:36 PM
Any update on first bug (CSCti19329) ?
Arash
05-15-2012 07:27 AM
any update on this Bug? any further information available?
05-27-2012 07:08 PM
Hey Guys,
The Defect: CSCti19329, indeed is cosmetic as long as the contacts in the contact list show correct "Available/Away/On The Phone" status as we utilize SIP Trunk for Presense Status.
This is cosmetic because of a DB schema change with CUCM 8.5. Even though CUPS 8.0(x) is supported with CCM 8.5, due to DB Schema change, that error message in generated in the System Troubleshooter.
If you were to upgrade to any version 8.5 or higher, that error message will go away.
Hope that helps clarify info on this defect.
Jas
