11-24-2018 09:43 AM
I;m trying to register a trunk between 2821 and Spectrum and keep getting the following message + timeout wait 100
068773: Nov 24 16:45:26.242: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
REGISTER sip:10.0.0.87:5060 SIP/2.0
Via: SIP/2.0/UDP 10.0.0.85:5060;branch=z9hG4bK5E461984
To: <sip:9001...@10.0.0.87>
Date: Sat, 24 Nov 2018 16:45:26 GMT
Call-ID: 96C6FD6D-EF3A11E8-82A19FD9-BC3554B5
User-Agent: Cisco-SIPGateway/IOS-12.x
Max-Forwards: 70
Timestamp: 1543077926
CSeq: 11 REGISTER
Contact: <sip:9001...@10.0.0.85:5060>
Expires: 3600
Supported: path
Content-Length: 0
Solved! Go to Solution.
04-30-2019 10:00 AM
Hi All;
Thanks for the assistance!
I don't know what was blocking the register but I used another interface to direct connect the sip trunk and it worked.
11-25-2018 12:58 AM
11-26-2018 09:27 AM
I did not have the bind in the config, added but still no joy
SIP User Agent Status
SIP User Agent for UDP : ENABLED
SIP User Agent for TCP : ENABLED
SIP User Agent for TLS over TCP : ENABLED
SIP User Agent bind status(signaling): ENABLED 10.0.0.85
SIP User Agent bind status(media): ENABLED 10.0.0.85
SIP early-media for 180 responses with SDP: ENABLED
SIP max-forwards : 70
SIP DNS SRV version: 2 (rfc 2782)
NAT Settings for the SIP-UA
Role in SDP: NONE
Check media source packets: DISABLED
Maximum duration for a telephone-event in NOTIFYs: 2000 ms
SIP support for ISDN SUSPEND/RESUME: ENABLED
Redirection (3xx) message handling: ENABLED
Reason Header will override Response/Request Codes: DISABLED
Out-of-dialog Refer: DISABLED
Presence support is DISABLED
protocol mode is ipv4
SDP application configuration:
Version line (v=) required
Owner line (o=) required
Timespec line (t=) required
Media supported: audio video image
Network types supported: IN
Address types supported: IP4 IP6
Transport types supported: RTP/AVP udptl
Then I noticed that all my internal extention's were trying to register.
Line peer expires(sec) registered P-Associ-URI
100 20140 0 no
101 20141 2 no
103 20142 3 no
104 20143 18 no
105 20144 19 no
107 20151 26 no
108 20145 27 no
109 20146 28 no
110 20147 33 no
111 20148 33 no
112 20149 35 no
113 20150 38 no
9* 1 39 no
9000... 20152 41 no
9001... 20153 42 no
what do I need to do to connect all those DID's???
04-30-2019 10:00 AM
Hi All;
01-11-2021 01:45 PM
Good afternoon, I know this is an old post but do you by chance have a sample config of your Cisco 2821 bound to an external SIP trunk provided by an ISP. I am currently setting up a Cisco 2821 that I have for testing in a lab environment and am having an issue connecting back to the SIP IP provided by my ISP. Thank you.
01-11-2021 10:57 PM - edited 01-11-2021 11:00 PM
I would advise you to create your own post instead of posting your question on an old post that is marked as answered.
You do the bind of interface on the dial peer(s) for it to know what interface to use for the communication with your SP. The rest is managed by the routing table on the router. There is no thing as such as binding to a SIP trunk.
01-12-2021 06:37 AM
01-12-2021 08:55 AM
Look at this document for how to bind media and control traffic to a specific interface. https://www.cisco.com/c/en/us/support/docs/voice/ip-telephony-voice-over-ip-voip/211306-In-Depth-Explanation-of-Cisco-IOS-and-IO.html
