03-27-2022 09:06 AM
Greetings,
I have a small deployment for IP Telephony Solution, 150 Users (Phones)
Do I need a cluster server that is for call manager express (CME) or the router ISR 4431 can handle calls?
also, what is the recommendation for PBX? is there ant alternative from cisco?
Solved! Go to Solution.
03-27-2022 09:19 AM
CME runs on a router, like the ISR4K. So there is no concept for cluster with this. It would provide the services that a PBX would do.
03-27-2022 03:22 PM
If you need to do clustering go with a CUCM model. AS @Roger Mentioned,CME will be running on Cisco router.
For licensing and other BOQ reach out to a local Cisco partner who is good in voice. Below mentioned are some documents which will be helpful for you.
03-27-2022 09:19 AM
03-27-2022 09:29 AM
Thank you for your kind reply
Would you please share a reference for deployment, requirements, licensing, etc..
Appreciate your help
03-27-2022 09:49 AM
All that is available at cisco.com. Go there and if you don’t find what you need please get back to this post.
03-27-2022 09:51 AM
I am already there... since last few days, scattered, old "out dated" artices, etc...
03-27-2022 09:56 AM
Not much that has changed with this topic in awhile, so even if it might seem outdated it likely is not.
03-27-2022 03:22 PM
