Soft client virtual machine
John Faltys
Level 4
Level 4
I would like to test CUCM calls remotely.
No VPN access, only remote desktop or VM Console.
CIPC does not work on remote desktop because it needs audio drivers.
X-Lite will not install as it wants a local drive.
Other ideas?
Thank you
Deepak Rawat
Ask someone to launch CIPC on the machine who has physical access to it and then you can use it on RDP.
Edit to the O.P. In case, if the machine hosting CIPC is created on a virtual environment then simply access it through Vsphere console directly (if you have access) and launch it that way and it should work then as well.
Deepak
Deepak Rawat
Deepak
