05-18-2016 07:16 AM - edited 03-19-2019 11:08 AM
I have upload image with the correct size to cucm tftp server. Restarted the server. I have created a new common phone profile and added the image but still will not work. I have also created an new List.xml file. I am able to go to <ip addressCUCM:6970>/Desktops/1600x1280x24/image.png via Endpoint but I can not apply the configuration to all devices. Not sure if I need to put the path or just image filename.
CUCM v10.5
DX70 v10.2.4
Solved! Go to Solution.
05-18-2016 07:45 AM
Change the path to 2985x1080x24
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCut54061/?reffering_site=dumpcr
Deepak
05-18-2016 09:08 AM
05-18-2016 07:45 AM
Deepak
05-18-2016 08:15 AM
So do I move image.png to 2985x1080x24 along with List.xml while creating a new Directory?
05-18-2016 08:17 AM
You don't need List.xml for these phone models.
Deepak
05-18-2016 08:38 AM
Do I just put in file name of image or do I add the whole directory path?
05-18-2016 08:39 AM
Define the whole directory path.
Deepak
05-18-2016 08:46 AM
should it look like this? And Apply Config?
05-18-2016 09:08 AM
Just the filename.
GTG
05-18-2016 12:03 PM
Thanks got it :>}
05-18-2016 08:12 AM
You can't set the wallpaper at the device level. You have to set it at the Common Phone Profile level.
GTG
