11-28-2015 09:11 AM - edited 03-19-2019 10:26 AM
Dear All
Kindly i have an issue with enable srst it is not work , we try to enable SRST in router 2901 and router license is
License Type: EvalRightToUse
License State: Active, In Use
Evaluation total period: 8 weeks 4 days
Evaluation period left: 8 weeks 1 day
and our CUCM V10.5 , and IP phones type 7841 and kindly find below running configuration:-
voice-card 0
voice register global
mode srst
system message SRST
max-dn 35
max-pool 35
application
global
service alternate default
license udi pid CISCO2901/K9 sn FGL192020HM
license accept end user agreement
hw-module pvdm 0/0
redundancy
voice-port 0/0/0
impedance complex2
description Line 1
caller-id enable
voice-port 0/0/1
impedance complex2
description line 2
caller-id enable
voice-port 0/0/2
impedance complex2
description line 3
caller-id enable
voice-port 0/0/3
impedance complex2
description line 4
caller-id enable
mgcp
mgcp call-agent 10.0.2.254 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode cisco
mgcp bind control source-interface GigabitEthernet0/0.2
mgcp bind media source-interface GigabitEthernet0/0.2
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
ccm-manager music-on-hold
ccm-manager fallback-mgcp
ccm-manager mgcp
ccm-manager config server 10.0.2.254
ccm-manager config
dial-peer voice 1 pots
destination-pattern 9T
port 0/0/0
gatekeeper
shutdown
call-manager-fallback
secondary-dialtone 9
max-conferences 8 gain -6
transfer-system full-consult
ip source-address 10.200.200.1 port 2000
max-ephones 35
max-dn 35
system message primary SRST
keepalive 20
time-zone 25
date-format dd-mm-yy
*** and we configure SRST reference in CUCM and Configure SRST in Device pool
11-28-2015 12:53 PM
Update
Dear all
voice service voip
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
registrar server
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
mode srst
system message SRST Service Active
max-dn 35
max-pool 35
voice register pool 1
id network 10.200.200.0 mask 255.255.255.0
dtmf-relay rtp-nte sip-notify
voice-class codec 1
application
global
hw-module pvdm 0/0
encapsulation dot1Q 2
ip address 10.200.200.1 255.255.255.0
mgcp
mgcp call-agent 10.5.5.200 service-type mgcp version 0.1
ccm-manager mgcp
ccm-manager config server 10.5.5.200
ccm-manager config
port 0/0/0
sip-ua
gatekeeper
shutdown
timeouts interdigit 2
ip source-address 10.2.2.1 port 2000
max-ephones 35
max-dn 35
system message primary SRST Mode
keepalive 20
time-zone 25
*** this is current configuration there is any missing configuration
