Survivable Remote Site Voicemail (SRSV) 8.6 Beta now open!
karmakar
Hello everyone,
Do you use or install Cisco Unity Connection? If your answer is yes - Are your users spread out in multiple branches across the WAN?
If the answer to these questions is yes, you need a cost effective solution for supporting redundant voicemail service for  your remote sites.
Cisco Unified SRSV  provides voicemail backup services to help ensure your remote site  continues to have voicemail service. This solution also provides  Automated-Attendant or call-handler services while in survivability  mode.
Some of the features we are introducing in version 8.6 are -
• Automated UMG Clustering and failover support - Automated seamless UMG clustering
• Centralized software upgrades - Touch free voice mail nodes are now automatically upgraded to the latest software version.
• Call handler support enhancements - One step closer to true resemblance with Unity Connection call handlers.
• Notification device support - Notification devices and schedules are synchronized as well ... automatically!
If you need more information about the product visit www.cisco.com/go/srsv. Contact me if you are interested in participating in the beta - karmakar@cisco.com
Abhi.
9 Replies 9
Sumit Bhargava
Need to provision Voicemail Redundancy for 350 VM users using Cisco Unified Messaging gateway and CUE8.6 at Remote Site
    HQ Site: Cisco Unity Connection8.6
    At Branch Site: on Voice Gateway 3925 ISR,  SM-SRE-700-k9 used for CUE8.6
                Cisco 3925 comes with two Service Module slots. In this case, one SM slot is used by CUE8.6 and the second SM Slot need to be
                factored for Cisco UMG (Unified Messaging Gateway).
                When we take the spare part code: SM-SRE-700-k9=, under this select Unifed Messaging 8.6 option(SUMG-SM7-86-k9), it later ask to
                select Feature license UMG Lic for 25E-SRST nodes/sites quantity. Waht is this required for since we are looking for SRSV and not E-SRST
               What should be the correct part code for unified messaging gateway using SM-SRE-700-K9
Also, noticed that SRSV capability of UMG has been annoucned EOS/EOL and the last day to order the product was
June 18, 2012:
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6789/ps5745/ps8605/end_of_life_notice_c51-695653.html
In such a case how to go about provisioning VoiceMail Redundancy using UMG?
If SRSV has been declared EOL/EOS and if Voicemail redundancy is required using UMG8.6, then what is the replacement for SRSV or is it that SRSV functionality has been incorporated into E-SRST license?
Thanks & Regards
Sumit
Sumit
SRSV architecture is changing next year. The BU is moving away from UMG which is why you don’t see that license orderable anymore. It will use Uconn natively to communicate with SRE module. Initial guidance is that it will only work with SRE 910 since the SRE will not be running CUE code but rather full blown Uconn code and the lower performance models don’t have the horsepower to run Uconn code.
Pricing/licensing for this new architecture is slated to be announced next year.
SRSV is completely different from E-SRST that still needs the UMG module
Srini
Hi Srini,
Thanks for the prompt reply.
Kindly confirm if the following understanding is correct.
1. Currently, Cisco UMG8.6 would only support E-SRST functionality and not voicemail redundancy since SRSV has been declared EOS/EOL.
2. Inorder to ensure Voicemail Redundancy, will have to run  Unity Connection (Active/Active) on two separate/diff UCS C210-M2 servers until SRSV architecture is changed next year.
3. As per the new SRSV architecture which is probably going to be released next year, instead of UMG Unity connection  will be used to communicate with SRE module (SM-SRE-910-K9)  and this SRE module will host full blown Unity Connection inplace of CUE
Thanks & Regards
Sumit
The only change I would say is for
1) If you are an existing customer you could deploy it but if you are new I would wait till the new architecture flushed out and the licensing was set in stone
Other points sound good see Uconn system requirements for BW requirements for clustering Uconn over the WAN
Srini
Hi Srini,
I noticed the same this morning when I was trying to find ordering information for SRSV functionality and I found out that the replacement solution will be native support in Unity Connection for SRSV. However, I am struggling to understand what components will be required for the overall solution.
My understanding is that UMG will not be required anymore on the central site as the capabilities for SRSV head end will be built into Unity Connection. Ofcourse there will be some license requirements on Unity Connection. Apart from that all we need is CUE module in the branch office gateway which, looking at your post, seems to be potentially an SRE 910.
Am i reading all this correctly?
Zeeshan
That us what the BU conveyed a while back to partners
Srini
Thanks Srini. Much appreciated!
Zeeshan
Hi All,
Here is an excerpt from the Design Guide for SRSV.
Overview of Cisco Unity Connection SRSV in Connection 9.1(1) and Later
Revised January 16, 2013
Cisco Unity Connection Survivable Remote Site Voicemail (Connection SRSV) is a backup voicemail solution that allows you to receive voice messages during WAN outages. It works in conjunction with Cisco Unified Survivable Remote Site Telephony (SRST) for providing voicemail service to a branch when the connectivity with the central Connection voicemail service is lost.
Connection SRSV is used in the centralized Cisco Unified Communications Manager and Cisco Unity Connection environment with multiple branch offices or small sites. It provides limited voicemail and auto-attendant features that remain in synchronization with the central Connection voicemail service so that when the WAN outage or failure occurs, the Connection SRSV solution can provide voicemail service to the subscribers at the branch. However, as soon as the network is restored, all the voicemails received by the branch subscribers are automatically uploaded to the central Connection voicemail server.
Connection SRSV solution requires the following two components:
Cisco Unity Connection: It is deployed at the central site alongside with Cisco Unified CM to deliver powerful integrated messaging and voicemail services.
Connection SRSV: The SRSV component is natively a part of Connection which is deployed at the branch site alongside with Cisco Unified CM Express or Cisco Unified Survivable Remote Site Telephony (SRST). Connection SRSV is hosted on  Cisco Integrated Service Routers Generation 2 (ISR G2) platform by using Services Ready Engine Virtualization.
See the following sections:
Supported SRSV Topologies
Scalibility
Connection SRSV supports several topologies based on the configuration of the router. You can deploy either original SRST or CUCME-as-SRST (also known as SRST Fallback Mode) at branch.
Note If you are running SRST at the branch site, you cannot also deploy the E-SRST feature.
Following figures show three topolgies supported by Connection SRSV:
Figure 14-1: Shows a topology in which SRST is deployed at the branch site. If the WAN occurs or PSTN goes down, Connection SRSV at the branch site provides limited voicemail support in the failover mode.
Figure 14-2: Shows a topology where CUCME-as-SRST (also known as SRST Fallback Mode) is providing call control at the branch site.
Figure 14-3: Shows a topology where multiple CUCME-as-SRST and SRSV devices are paired for load balancing at the survivable branch site. In this scenario, the administrator uses Cisco Unified Communications Manager to divide the branch users between CUCME-SRST-1 and CUCME-SRST-2. The central Connection server detects that and then sends the appropriate configuration to SRSV-1 and SRSV-2 at the branch site. In the event of WAN failure, each SRSV device will handle calls directed to it from the paired CUCME-as-SRST device.
Figure 14-1     Topology 1
Figure 14-2     Topology 2
Figure 14-3     Topology 3
Scalibility
Each Connection SRSV branch will support 200 users per branch with a maximum of 10 branches per centralized Connection server.
Software Requirements
Connection SRSV requires Cisco Unity Connection minimum version 9.1 for both the Central Connection server as well as the SRSV branches.
Bandwidth requirements for synchronization to central Connection server after outage
The synchronization process does not have any bandwidth requirements as it is not a real-time process.
Supported Hardware
Any supported Connection hardware is suitable for Connection SRSV. Please see the current Supported Platforms List for the most up to date list of supported hardware.
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/9x/supported_platforms/9xcucspl.html.
Limitations
No MWI
No interaction between existing UMG based SRSV and Unity Connection based SRSV
No migration from UMG based SRSV
Sumit Bhargava
Thank You Srini  :-)
Thanks & Regards
Sumit
