10-18-2010 08:18 AM - edited 03-19-2019 01:46 AM
I have a question, anyone know how to change the screen image of a phone Tandberg e20?
10-18-2010 02:29 PM
Hi Liliana,
I'm not familiar with that product, however, I looked on the Knowledge base and found this:
"You can change the TANDBERG EX90 wallpaper and inTouch background by pushing and holding for approximately 2 seconds on any open spot on the inTouch main screen. This will display the pre-defined wallpapers."
Probably this is similar to what you need for the E20.
HTH,
Tere
11-19-2010 02:49 PM
I am also trying to see if there is a way to upload a custom image to use as the background on the inTouch touch screen used on the EX90.
Is there a way to do this? I know how to touch the screen to choose from the predefined backgrounds, but I want to upload a custom image.
Mike W.
