Tandberg E20
lperez235
I have a question, anyone know how to change the screen image of a phone Tandberg e20?
testeven
Hi Liliana,
I'm not familiar with that product, however, I looked on the Knowledge base and found this:
http://www.tandberg.com/support/video-conferencing-knowledge-base/faq-topics/specifications-12/change-tandberg-ex90-wallpaper-intouch-background-614.jsp?search=
"You can change the TANDBERG EX90 wallpaper and inTouch background by  pushing and holding for approximately 2 seconds on any open spot on the  inTouch main screen. This will display the pre-defined wallpapers."
Probably this is similar to what you need for the E20.
HTH,
Tere
Regards, Tere. If you find this post helpful, please rate! :)
goldchain
I am also trying to see if there is a way to upload a custom image to use as the background on the inTouch touch screen used on the EX90.
Is there a way to do this?  I know how to touch the screen to choose from the predefined backgrounds, but I want to upload a custom image.
Mike W.
