07-31-2011 08:55 AM - edited 03-19-2019 03:21 AM
The get call contact info step
callerID=
Get Call Contact Info (--Triggering Contact--, Calling Number)
does not pickup the correct callerid - as far as i can tell from the if statement used afterwards.
From Real time monitoring I can see the Calling no to be shown correctly but the:
ANI
CLID
show nothing.
Should the CLID be showing the correct Calling No too,
Or how else can I check that my callerID variable contains the correct info ?
Thanks.
Solved! Go to Solution.
07-31-2011 11:26 AM
Run a reactive debug of the script to see what the step sets the variable to on a live call.
Aaron
07-31-2011 11:26 AM
Aaron
04-21-2022 11:47 AM
I have a same problem can someone help me how can I get original calling number for the external forwarded calls.
04-21-2022 11:50 PM
Please post your question in a new post as this post is very old and on top of that is marked as answered. That will get you a better chance of getting the help needed for this.
