ucm 8.5 to ucm 8.6 upgrade
renji joy
Hello Team,
We are using call manger version ucm 8.5.1and we have to upgrade ucm 8.6 for that we need any extra license or we can use the same license which is there in current version.
Suggest for the same.
Thanks in Advance
you are using Restricted version .
you can upgrade to CUCM RST version 8.6(2a) SU5 [8.6.2.25900-8]
COP file needs to be installed first before u upload the patch of 8.6(2a)SU5.
once the cop file is uploaded, u can see by using command show version active through CLI of OS administration of that server in a cluster.
regds,
aman
12 Replies 12
Wilson Samuel
Level 7
Level 7
8.x you should be able to use the same Lic, however if you have UCSS, why not upgrade to 10.5 ?
to be sure, check with your cisco account rep
hth
Thanks guys
Thanks for the usual support..
Renji
No worries please mark the thread as answered if you have no more queries.
-Terry
[+5] to Terry and Wilson.
Hi Renji,
Minor upgrades do not require ay UCSS contract.
Prior to upgrading to 8.6, refer compatibility matrix along with Restricted/Unrestricted version which u need to download [patch ]
Lastly,also look into cop file.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/compat/ccmcompmatr1.pdf
regds,
aman
We are going to upgrade system version 8.5 to 8.6 2a so that we can use restricted
version patch right ?
Also need to install any refresh upgrade before upgrading ciscocm.refresh_upgrade_v1.0.cop.sgn on 8.5.1(x) before upgrading to 8.6.2a.
Hi ,
are u using Restricted/Unrestricted version?
u can refer attached snapshot
regds,
aman
Cop file would be required in both cases whether u are using RST or UNRST.
regds,
aman
Thanks Aman
We are using restricted version please find the attched scrrenshot.
please tell me need to install any refresh upgrade before upgrading ciscocm.refresh_upgrade_v1.0.cop.sgn on 8.5.1(x) before upgrading to 8.6.2a.
regds,
aman
Hi Renji,
If you are using Restricted version, you CANNOT upgrade it to Unrestricted version.
The 8.5 to 8.6 and above will always require the COP file because there is a kernel change of RHL (it goes from RHL 4.x to RHL 5.x) and the COP file facilitates just that.
Aman (+5) mate for adding further useful info.
-Terry
Terry Cheema
8.5 to 8.6 upgrade does not require any license.
-Terry
