UCS BE6M-M5-K9 not booting up - stuck in CISCO splash screen
Liv_Liv
Im just trying to set up a brand new UCS-C220-M5 and having serious difficulties,
After configuring the CIMC addressing, I found out that the hard drives (6 x SAS SFF HDD) are not being detected.
I need to get to the Hypervisor configuration utility screen but in this version, seems that you need to manually build the RAID by enabling the controllers in the BIOS boot screen...according documentation:
Enabling SATA Mode For the Embedded Controllers
This procedure uses the server's BIOS Setup Utility.
Note
If you use an embedded RAID controller with Linux, both the pSATA and the sSATA controller must be set to LSI SW RAID mode.
Procedure
Step 1
Boot the server and press F2 when prompted to enter the BIOS Setup utility.
Step 2
Set the SATA mode:
  1. Choose the Advanced tab, and then choose LOM and PCIe Slots Configuration.
  2. For the primary pSATA controller, select pSATA and then choose one of the options from the dialog:
    • LSI SW RAID—Enable the embedded pSATA RAID controller.
      Note
      This menu option does not appear when the server is set to boot in Legacy mode (UEFI mode is required). To change the boot mode, use the BIOS setting for Boot Options > Boot Mode.
    • Disabled—Disable the embedded pSATA RAID controller.
  3. For the secondary sSATA controller, select M.2 and then choose one of the options from the dialog:
    • LSI SW RAID—Enable the embedded sSATA RAID controller for control of internal SATA M.2 drives.
      Note
      Note
      This menu option does not appear when the server has no M.2 mini storage module, or when no SATA M.2 drive is installed in the mini-storage module.
    • AHCI—Enable control of the internal SATA M.2 drives by AHCI through your OS rather than the embedded RAID controller.
    • Disabled—Disable the embedded sSATA RAID controller.
Step 3
Press F10 to save your changes and exit the utility.
The problem I have is that, in order to configure the RAID and access the disks utility, boot mode needs to be set to UEFI. I changed boot mode to UEFI but now the server is not booting up, and doesn´t allow to access BIOS or CIMC config at all, It is stuck in the following screen:
I tried erasing settings to default mode on both the BIOS and the CIMC but once I reboot the server it keeps stuck in the exact same screen. I have no way to return to factory state...
Any clues?
thank you,
It happens while  shipping. Reinsert the raid controller.  I faced such issues couple of times and reinserting the raid card resolved the issue.
You don't need to reconfigure the raid.
Remove the power  cord Wait  15 mins,  and reinsert the power for CIMC.
Response Signature
Hi Nithin
thanks for your suggestion. I will try to reseat the controller tomorrow at office and get back to you with the results.
However Im worried because at this stage the server is unresponsive no matter what key you press on the splash screen, Im not able anymore to access boot options or CIMC config even after restore all settings to factory default, is there anything I can do or should I request an RMA?
thanks,
For CIMC issue, remove the power wait 15 mins and reconnect the power. Most probably it could resolve.
Reinsert the raid card and let the server boot with preinstalled VMware. then restart the server and go to CICM configuration page and do the configuration.
if the above  doesn't help we can think of RMA. I faced similar issue couple of times.
Response Signature
