UCS c220 m3 not power on and have some logs
I have some issue with UCS c220m3 having some issue when i power on i have check the log and get the following. Please tell me what to do to solve the issue since.
Manish Gogna
Looks like you forgot to attach the error. You can use the following troubleshooting guide for UCS C series to look for possible solutions
http://www.cisco.com/c/en/us/support/docs/servers-unified-computing/ucs-c200-m1-high-density-rack-mount-server/111508-tshoot-tips-cimc.html#Poweron
Manish
Thanks for the reply. Please check attachment.
There are multiple faults within a space of 2-3 minutes related to memory, cpu, power supply etc. The following link provides details about these faults
http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/c/sw/fault/reference/guide/Cisco_UCS_C-Series_Servers_CIMC_Faults/CIMC_Faults.html#wp1054402
However, it would be best to contact TAC if you have a valid contract.
Manish
