Unable to connect to 2801 using CCP and HTTPS
aaron-saz
I have a 2801 Router and am unable to connect using CCP via HTTPS.  I can connect using CCP via HTTP.
Below is some info on my setup and error message. Does anybody have any thoughts? I don’t get the pop up in CCP to accept the cert. Wondering if this is IE issue, or CCP / java issue.  Running-config is attached.
Router:
- 2801
- c2801-ipvoicek9-mz.151-4.M12a.bin
PC:
- Win 7
- IE 11
- Java: build 1.8.0_121-b13
Error:
- “Discovery could not be completed because security certificate was rejected. See help for more information.”
aaron-saz
I might have found a solution with downgrading java.
