Unable to send calls to Voicemail from CUPC for external calls
alalli
Level 2
Level 2
Hi All,
We have the CUPC client installed and working here, but I am not able to use immediate divert to voicemail on the CUPC client for external calls.
The used desk phone for audio box is ticked.
When an internal call comes through; I can push that call to voicemail.
If the call is external,  I get an error message and the phone continues to ring.
When I untick the use desk phone
Both internal and external calls are diverted to the voicemail port.
Can someone please let me know if the divert to voicemail should work when the use desk phone for audio box is ticked?
Thanks for any help
Amanda Lalli-Cafini
anchoudh
Level 9
Level 9
Hi Amanda,
Please keep in mind that CUPC 8.x client uses the "Client Services
Framework" Device Type for soft  phone and CUPC 7.x uses "Cisco Unified
Personal Communicator" Device Type.
Please refer to the CUPC Soft Phone Configuration section of the
Deployment Guide:
http://www.cisco.com/en/US/docs/voice_ip_comm/cups/8_0/english/install_u
pgrade/deployment/guide/dgclient.html#wp1135277
Also the change in CUPC 8 is that the device change from Desk Phone and
Soft Phone is at the bottom of the Client, where, if everything is
configured correctly, you should have a check box at the bottom saying
Use my Cisco xxxx Phone for Audio. If that box is checked then the Desk
Phone is being used and if it is unchecked then Soft Phone is Used.
Sometimes when you don't see a checkbox, then, the following could be
happening: 1) Only Desk Phone is Configured and working correctly 2)
Only Soft Phone is configured and working correctly 3) Neither Soft
Phone or Desk Phone are working.
Hope it helps.
Anand
Please rate helpful posts !!
ronpatel
Level 8
Level 8
Hi Amanda,
This sounds to me like the issue when voicemail pilot number is not
configured on CUCM. Go to CUCM->advanced features and there check
configurations for voice mail pilot and voice mail profile. If voice mail
pilot is not set this would affect only deskphone mode in CUPC as you
described.
Ronak patel
Please rate all helpful posts by clicking stars below the answer
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Hi All,
It turned out to be a CSS issue on the voice gateway.
Once the voice gateway could call the voicemail pilot,  it worked fine.
Thanks so much for your help though.
Amanda
