10-11-2004 06:55 AM - edited 03-18-2019 03:40 PM
Hello ,
We have unity 3.1.3 and excahnge 5.5 on box.We want to upgrade unity 4.04 voicemail .Can any please confirm that exchange 5.5 supported on box with unity 4.0.4
Radhika
10-11-2004 09:59 AM
Technically it is supported still however the time will come when we end of life support for that type of configuration because Microsoft is planning to end of life support for Exchange 5.5. If you are going to do the upgrade now might be a good time to get on Exchange 2000 to ensure future support.
Keith
10-11-2004 10:05 AM
Keith,
This is a part of the migration that we doing from voicemail to unified.WE have 3.1.3 and exchange 5.5 on box.There are two other server for new unified messaging.So after the migration it will be unified messaging wiht 4.0.4 with off box Exchange 2000.
What I was thinking is upgrade the exsisting voicemail only server to 4.0.4 take Dirt backup.Thats the reason that I was asking about exchange 5.5 and unity 4.0.4
Install 4.0.4 on the new servers and restore the backup on the new box.Then use "migrate subscriber data" to map the subscribers of exchange 5.5 to exchange 2000.
Can you please verify the process of the upgrade and any precaustions to be taken.
Radhika
10-11-2004 10:39 AM
OK I see what you are doing and that will work fine.
Keith
10-11-2004 10:40 AM
Keith,
Thanks a lot for your input on this.
