04-28-2010 01:57 PM - edited 03-19-2019 12:51 AM
We have Unity 5.0 in a failover configuration with Exchange 2007 partner and mail store servers. Our Exchagne 2k7 servers are being patches with SP 2 in a few weeks. I have the Exchange 2k3 system management tools installed on our Unity servers so I am not sure if we need to install this service pack or if there is any impact to our system if it is installed on our Exchange partner/mail servers. Any assistance, specifically with installation documentation or best practices would be greatly appreciated.
Thanks!
Michele Russo
04-28-2010 10:24 PM
The Exchange 2K3 System Management tools installed on the Unity servers should be fine. Unless there is a patch directly related to the E2K3 tools (not Exchange 2007 itself) then I'd leave Unity as-is.
Hailey
Please rate helpful posts!
04-30-2010 06:31 AM
Thanks for the response David. Do you know where I can get the E2K3 management tools? The Message store disks were not shipped to me when I placed the order and our Exchange team can not seem to find their copy.
Michele
04-30-2010 07:49 AM
Michelle,
Unfortunately, you need either the Message Store disc or a copy of the commercial Exchange 2003 CD/DVD to install the Sys Mgmt tools. If you are current on support for Unity, you should be able to use the Product Upgrade Tool (PUT) on Cisco.com with a valid CCO login to order a replacement disc. I'd take a look there first if your Exchange guys can't muster up a copy of the disc internally.
Hailey
