07-21-2005 02:47 AM - edited 03-18-2019 04:50 PM
Unity Unified V4.0(3) Messaging Installation with Exchange 2003 server as the message store. Unity is on a seperate server. NSI Double-Take is going to be used to set up a 2nd server as a backup server to the exchange 2003 message store.
Is this supported with Unity?
Is anyone running this scenario?
Are there any gotchas?
thanks,
stuart
08-30-2005 07:40 AM
Hi Stuart,
Have you been able to get any info in regards to your questions? I'd also like to use NSI Double-Take for my Ex2K3 which is a partner server for my UM Unity 4.0(4) on a separate box.
TIA.
Rasim Duric
09-05-2005 12:31 AM
No I haven't any positive information about this. I believe the double-take backup server assumes the ip address and name of the primary so it should work ok but I don't know for sure.
