Unity and NSI Double-Take
scoe
Unity Unified V4.0(3) Messaging Installation with Exchange 2003 server as the message store. Unity is on a seperate server. NSI Double-Take is going to be used to set up a 2nd server as a backup server to the exchange 2003 message store.
Is this supported with Unity?
Is anyone running this scenario?
Are there any gotchas?
thanks,
stuart
rduric
Level 5
Level 5
Hi Stuart,
Have you been able to get any info in regards to your questions? I'd also like to use NSI Double-Take for my Ex2K3 which is a partner server for my UM Unity 4.0(4) on a separate box.
TIA.
Rasim Duric
No I haven't any positive information about this. I believe the double-take backup server assumes the ip address and name of the primary so it should work ok but I don't know for sure.
