Unity Connection 1.2 and Unity Enterprise 4.0.4
e.giron
Level 4
Level 4
My client has two flavors of Unity running Connection 1.2 and Enterprise 4.0.4, they originally purchased Connection but it didn't intergrate with Lotus Notes, so thats when the Unity 4.0.4 came in, now we are approaching end-of-life and we need to upgrade to Unity 7.0/Call Manager 7.0 does anyone have a reference for this I've been looking at how to merge both Unity Databases to the 7.0 and cannot find it.
Tray Stoutmeyer
This link should have everything you need to go from UC 1.2 to UC 7.x
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/7x/upgrade/guide/7xcucrug020.html
But I just realized you want to go from UC 1.2 to Unity 7.0 which is not a supported path. You can only go from Unity to UC and not the other way around. Hopefully I read your question correctly. If you are trying to upgrade to UC 7.0 then the link above is valid. If you are migrating form UC 1.2 to Unity 7.0 then I am afraid there isn't a path for that.
Tray
Tray Stoutmeyer
Tray
I think this guide helped I saw that I can go from Connection 1.2 to Connection 7.0 using COBRAS, and I would have to upgrade Unity 4.0.4 to 4.0.5 in order to import that data to Connection 7.0
Thank you.
