Unity Connection 10.5.2 failover doesnt work
Mark Verwey
Last weekend my CUC publisher went down, the subscriber should have taken over as the ports stayed registered and the configuration is a HA setup but for some reason until I rebooted the publisher none of my calls would answer unless someone picked the line ringing.  I guess you could call it dumb luck as I had been out late, I saw the RTMT alert and was able to reboot the server and no one was the wiser.  How do I fix this so that next time the server is supposed to fail over it does.
Are the subscriber ports a member of the line group in CUCM?
5 Replies 5
devils_advocate
Level 7
Level 7
On the configuration of the VM ports on your subscriber, do you have 'Answer Calls' enabled?
Telephony Integrations > Port
Yes, both the Publisher and Subscriber have the Answer Calls enabled.
That's what is missing, thanks for the help.  Now it should work as designed.
Awesome, thanks for the update. Please mark as helpful and/or resolved.
