Unity Connection 411 STATUS ERROR
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
06-10-2015 08:50 AM - edited 03-19-2019 09:41 AM
When I go to reset a password for an extension, user gets a 411 status error and goes back to the search. I can not figure out why.
Any ideas why I'm getting a 411 status error?
- Labels:
UC Applications
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-10-2015 10:33 AM
What password?? PIN or GUI??
Also, local user? LDAP? AXL?
java
if this helps, please rate
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-10-2015 11:33 AM
PIN
LDAP
CUC 10.5
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-10-2016 05:55 AM
Any update on this issue? I am experiencing it as well for a single user (so far) in CUC 11, non-LDAP integrated.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-10-2016 10:28 PM
Is it a single server CUC or a you have a subscriber as well. In case, you have a subscriber as well what is the status of replication and are you able to change it from other server in that case
utils dbreplication runtimestate
Deepak
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-14-2018 09:57 AM
I'm seeing this same problem on a 10.5 UCxN cluster. You see the 411 error from the subscriber, but not on the pub. But we are seeing issues that make us suspect a replication problem. LDAP synced infrastructure.
When we delete a user that is gone, and create a new user from LDAP with the same extension, it is retaining the old users greeting file. And the new user cannot log in (in fact, we aren't even seeing a login failure). Kind of makes me think it's replication related.
But I cannot even find a reference to tell me what the red ball with an "X" in it with the number 411 beside it even means.
The application administrator is already set to never expire.
I've asked the customer to reboot the cluster tonight and we can check it, but would really appreciate some helpful suggestions.
TIA
