Unity Connection 9.1.2 - MS Exchange 2013 support for Single Mailbox?
Michael Hamann
we are currently running a unity connection system in version 9.1.2TT1.11900 together with single mailbox enabled with our Exchange server in version 2007.
We are now planning to upgrade the exchange server to version 2013. From my understanding Exchange 2013 is supported with CUCN 9.1.2 (see http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/9x/design/guide/9xcucdgx/9xcucdg020.html).
When i go to the configuration screens I cannot choose Exchange 2013 ... Is there a special way to configure this or is 2013 not supported with Unity connection 9.1.2 ?
any hints ?
Michael
Anirudh Mavilakandy
Exchange 2013 is supported.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/9x/unified_messaging/guide/9xcucumgx/9xcucumg020.html#17832
  • If you choose to allow Unity Connection to search for Exchange servers, then you need to select from the following two options:
 Exchange 2007 and/or 2010: Unity Connection can access every mailbox in the Exchange organization consisting of Exchange 2007, Exchange 2010, and Exchange 2013.
 Exchange 2003, 2007 and/or 2010: Unity Connection can access every mailbox in the Exchange organization consisting of Exchange 2003, Exchange 2007, and Exchange 2010. When the Exchange organization includes Exchange 2003 servers, Unity Connection always communicates directly with the Exchange back-end servers, it never communicates with Exchange front-end servers.
The drop down does not state 2013 but it will work fine for 2013..
