unity connection classic conversation
AskQ2Forum_2
                unity connection 8.6, the classic conversation allows a message to be marked private, i have used custom keypad 1 - where can i enable the 'marked private ' option , it does not allow it.     is it possible to view the settings in classic conversation ?...thanks, Jag
Rob Huffman
Hi Jag,
You can set this on the Edit Message settings page for the users;
Message Settings
* seconds
Language That Callers Hear
Message Urgency
We use a custom conversation as well and this is where it needs to be set You
can use bulk edit to change it for existing users and set on the Template for users
that you are creating as new.
Cheers!
Rob
"Your life is worth much more than gold."
- Bob Marley
Rob Huffman
Hi Jag,
Message Settings
* seconds
Message Urgency
Cheers!
Rob
- Bob Marley
thanks again 'top man'
