Unity Connection - Disk Voluming
g-paulson
Taking the defaults of a Unity Connection platform installation builds a qty of 5 volumes. (Drive C through Drive G)
Can this be correct?
Brandon Buffin
Yes, that is possible. Best practices recommend to separate OS, SQL database, transaction logs, Unity logs, etc. by using different partitions. Take a look at the Drive Locations for Files on a Large-Scale System section in the following link.
http://www.cisco.com/en/US/products/sw/voicesw/ps2237/products_installation_guide_chapter09186a008022b969.html
Hope this helps. If so, please rate the post.
Brandon
Greg
For UC 1.1.1, what is drive d, e , and f used for?
Thx
g-paulson
Opened a TAC case, this is correct.
Also found out that "NTVDM encountered a Hard Error" is caused by bad media shipped by Cisco. Fix is to download from CCO
