Unity Connection Express 8.5 not sending Voicemails to Email
hsmith365
I have CUE 8.5 on a 2921 router. All of the servers and server IPs are correct. The mailbox is configured correctly with the correct email address, The enable notification to this device CHECKED, the attach message to outgoing email notification CHECKED, and every checkbox in the schedule checked. It is set to send All Messages. On the Exchange, the IPs of the router has been added to permitted relay so it can send emails to the Exchange. However, when I call the number and leave a message, it does not forward the message to the email address listed.
Any Advice would be great!
Rob Huffman
Hi Heather,
This is a really good doc that lists the required steps
https://supportforums.cisco.com/docs/DOC-11798
Cheers!
Rob
Please remember to tag your threads and help support "Teachers without Borders"
https://supportforums.cisco.com/community/netpro/idea-center/communityhelpingcommunity
Mr. Rob,
All of these steps were taken and we still cannot get the voicemails notifications sent to email.
I'm experiencing the same issue.  Configuration on CUE looks good, all required boxes are checked.  Did you ever find a solution?
James
