Unity connection Greeting
shazeb051
Dear Experts.
i am unable to record greeting when i add it its giving error
Unable to save recording due to SSL certificate errors
what can i do to make this.
Thanks and regards,
7 Replies 7
Deepak Rawat
Try using this tool:
http://www.ciscounitytools.com/Applications/CxN/ATM/ATM.html
Deepak
Deepak Rawat
Adding to my previous response you can also try the below workaround as for one off occasion but from a future perspective you should start using ATM for these kind of things that completely eliminates JAVA related issues:
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCto92753/?reffering_site=dumpcr
Apart from this, try downgrading the JAVA version to something like 7 update 51 and then in the JAVA control panel, choose the security to the lowest and add Unity Connection web site in the Exception List.
Deepak
Dear deepak for loggin its giving error please see the attachment below tried by ip and host name both.
thanks.
You will need ODBC for this, set up that first:
http://ciscounitytools.com/Applications/CxN/ATM/Help/ConnectionAudiotextManager.htm#_Toc422978763
How about trying the options that I provided in my second response.
Deepak
from where i get this??? cisco site??? and one more thing i have java 8 ..should i degrade it?
http://www.ciscounitytools.com/Applications/CxN/InformixODBC/InformixODBC.html
With Java 8, try setting the security to high and put the complete URL that you are using to upload recording in the Exception list. If that does not work, then go for uninstall and reinstall v7 update 51 for JAVA and disable the security and add the URL to exception list and then try.
Deepak
Rob Huffman
Hi there,
In addition to the great help from my friend Deepak (+5) you can also try the work around listed in this bug (seems to work for versions 8.6 right through to 10.5);
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuv32210
CUC Greetings Upload "failed to record name"- Java 1.8
CSCuv32210
Symptom:
Attempting to upload greetings file for user or call handler using the CUC Administration web page.
Java applet loads and can open file, but when hit "save" on page, see error message "failed to record name"
Conditions:
Workaround:
Before hitting "save" on page, use applet to play the file back to phone, as described in supportforums article:
https://supportforums.cisco.com/discussion/12188606/cisco-unity-connection-86-cannot-upload-greeting
